This DisplayPort 1.4 cable lets you connect your DP laptop or desktop computer to an ultra-high definition 8K monitor, TV or projector.
The DP monitor cable provides the essential final link in your audio-video setups and is ideal for: Delivering enriched presentations; Displaying crisp digital signage walls; Creating eye-catching visuals for photography, videography, cinematography; Producing lifelike gaming.
This DP cable is VESA certified to ensure full compliance and efficient operation of the higher link rate of HBR3. It has been tested to meet all DP 1.4 specifications to ensure quality and reliability.
This 8K DisplayPort cable supports all DP 1.4 features: Resolutions up to 8K (7680x4320) @ 60Hz, backward compatible with 5K (5120x2880) @ 60Hz and 4K(4096x2160) @ 120Hz and previous generations of DP; High Bit Rate 3 (HBR3) bandwidths of 32.4Gbps; High Dynamic Range (HDR) for higher contrast ratio and vivid colors; Multi-Stream Transport (MST) for daisy-chaining multiple monitors; Display Stream Compression 1.2 (DSC); Forward Error Correction; 32 uncompressed digital audio channels; HDCP 2.2.
The cable has a thinner 34 AWG construction that allows for flexible installation with minimal clutter, which is perfect for offsite assignments. Each connector features latches that provide secure connections between your devices.
- StarTech.com 3ft/1m VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HBR3 HDR, Super UHD DisplayPort to DisplayPort Monitor Cord, Ultra HD 4K 120Hz DP 1.4 Slim Video Cable M/M DP Connectors - DP 1.4 Latching Cable - DisplayPort cable - DisplayPort to DisplayPort - 1 m
- DisplayPort cable
- 8K support, flexible, Ultra HD (8K) support, HBR3 support, maximum resolution 7680x4320 at 60Hz, HDR support, 32 uncompressed digital audio channels, Multi-Stream Transport
- Length
- 1 m
- Connector
- 20 pin DisplayPort - male - latched
- Connector (Second End)
- DisplayPort 1.4
- Black
- Limited lifetime warranty
- Designed For
- P/N: CDP2DPHD, CDP2DPVGA, SV231QDPU34K, TB32DP14
- DisplayPort cable
- Length
- 1 m
- Black
- Connector
- DisplayPort 1.4, HDCP 2.2, DSC 1.2
- Designed For
StarTech.com 1m 3.3ft DisplayPort 1.4 Cable | In Stock | £13.02 |
StarTech.com 2m 6.6ft DisplayPort 1.4 Cable | In Stock | £15.18 |
StarTech.com 3m 9.8ft DisplayPort 1.4 Cable | In Stock | £29.12 |
StarTech.com 5m DisplayPort 1.4 Cable | In Stock | £34.31 |
