StarTech.com 1m/3.3 ft Premium High Speed HDMI Cable with Ethernet
Quicklinx: FKF5WS00 Mfr#: RHDMM1MP
Length: 1m
Hurry, only 3 left in stock!
£12.03 ex VAT
£14.43 inc VAT
This 3 ft. (1 m) High Speed HDMI Cable with Ethernet withstands the daily demands of connecting your HDMI devices. Tested to endure strenuous wear and tear, the rugged cable is a must-have for both business and consumer applications.
The HDMI Premium Certified cable has aramid fiber reinforcement that braces it from the stress of frequent bends from hooking up your TV or monitor. This also lets the cord flex without over-stretching or damaging the core of the cable.
Cable Key Features. Aramid fiber adds strength and durability to the cable; Insulated conductors reduce friction, provide more flexibility; EMI protection with aluminum-mylar foil with braided shielding; TPE cable jacket is more flexible than a standard PVC cable.
The high quality cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. HDMI gold plated connector with metal shield protects the circuit board from EMI and reinforces the connection point; Strain relief tested to tolerate over 10,000+ bend cycles at a 180° angle.
Supporting all HDMI 2.0 specifications, this HDMI Premium Certified adapter cable supports resolutions up to 4K 60Hz with a bandwidth of up to 18Gbps. The HDMI cable also supports HDR for higher contrast ratio and vivid colors providing an enriched and enjoyable viewing experience.
  • Durable construction
    The cable is constructed with aluminum mylar foil shielding and braid to ensure long-lasting performance, making it suitable for everyday use.
  • High-speed support
    Designed as a Premium High-speed HDMI cable with Ethernet, this cable supports fast data transmission for both audio and video applications.
  • Enhanced compatibility
    With 19-pin HDMI Type-A connectors on both ends, this cable is compatible with devices such as TVs, monitors, and projectors.
  • Eco-friendly compliance
    The cable adheres to RoHS, WEEE, and REACH standards, reflecting a commitment to environmental safety in design and production.
  • Reliable performance
    Featuring a 30 American Wire Gauge (AWG) construction, this HDMI cable is designed to ensure optimal signal quality and performance reliability.
StarTech.com 1m Premium Certified HDMI 2.0 Cable with Ethernet, Durable High Speed UHD 4K 60Hz HDR 10, 3ft Rugged M/M HDMI Cord with Aramid Fiber, TPE, Ultra HD Monitors, TVs & Displays - Heavy duty HDMI cable - HDMI cable with Ethernet - 1 m
Cable
Premium High Speed - HDMI cable with Ethernet
30
Length
1 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K format support, HDR support, EMI/RFI protection
P/N: TB3DKM2HDL
Cable Type
30
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS, WEEE, REACH
35 g
Shipping Width
18.2 cm
Shipping Depth
15 cm
Shipping Height
2 cm
Shipping Weight
40 g
Limited warranty - lifetime
P/N: TB3DKM2HDL
Length: 1m
