Deliver fast, reliable, data transfers, safely over high end networking equipment. The A50FBLCLC1 1m 850nm Laser-Optimized Multimode Fiber (LOMMF) Aqua Cord features 50/125 micron fiber for high-speed, high bandwidth data transmissions over 10 Gigabit Ethernet and Fiber Channel networks - the perfect solution for fiber cable runs between multiple backbone switches, hubs and routers as well as higher end networking equipment.
This LC-LC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire - an ideal solution for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each Duplex 50/125 (OM3) Multimode Fiber Patch Cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
Efficient connectivity
This cable features two LC multimode connectors, allowing for seamless and reliable data transmission between devices, enhancing network performance. -
Enhanced safety
The Low Smoke Zero Halogen jacket reduces the release of toxic fumes in case of fire, providing extra safety in various installations. -
High data capability
With a core diameter of 50 microns, this multimode fiber optic cable offers bandwidth capabilities, suitable for various applications that require fast data transfer.
- StarTech.com 1m (3ft) LC/UPC to LC/UPC OM3 Multimode Fiber Optic Cable, Full Duplex 50/125µm Zipcord Fiber Cable, 100G Networks, LOMMF/VCSEL, <0.3dB Low Insertion Loss - LSZH Fiber Patch Cord - patch cable - 1 m - aqua
- Patch cable
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Length
- 1 m
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- 2 x LC multi-mode - male
- Connector (Second End)
- Aqua
- Limited lifetime warranty
- Designed For
- P/N: 455883B21ST, EXSFP10GESRS, J9150AST, J9152AST, MASFP10GBSR, SFP10GBLRMST, SFP10GBSRST, SFP10GLRMST, SFP10GSRSST, SFP10GSRST, SFP10GSRSTTA, SFP10GSRXST
- Network Cable Type
- Patch cable
- Technology
- Multimode
- Jacket Material
- Low Smoke Zero Halogen (LSZH)
- Fibre Qty
- 2
- 50 / 125 micron
- Length
- 1 m
- Aqua
- Connector
- RoHS
- Designed For
StarTech.com 2m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £19.09 |
StarTech.com 3m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £17.93 |
StarTech.com 10m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £34.49 |
StarTech.com 1m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £17.60 |
StarTech.com 5m 10 Gb Aqua Multimode 50/125 Duplex LSZH Fiber Patch Cable LC - LC | In Stock | £25.04 |
StarTech.com 7m OM3 LC to LC Multimode Duplex Fiber Optic Patch Cable | In Stock | £25.62 |
