StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad
Quicklinx: 8T5HWS00 Mfr#: USBLT1MW
Length: 1m
Colours:
More than 50 in stock
£11.71 ex VAT
£14.05 inc VAT
Charge and Sync your Apple Lightning-equipped devices. The USBLT1MW 1m White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com White Apple 8-pin Lightning to USB Cable for iPhone iPod iPad - Lightning cable - Lightning / USB - 1 m
Cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
Apple 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; 4; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE; iPod nano (7G); iPod touch (5G, 6G)
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini , Apple iPad mini 2 , Apple iPad mini 3 , Apple iPad mini 4 , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, SE , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
8T5H StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.21
8T5H StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £3.83
8T5H StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £1.27
8T5H StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £3.58
8T5H StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £3.07
8T5H StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £11.71
8T5H StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £5.23
8T5H StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F In Stock £4.88
Length: 1m
Price Range Ex VAT: 0 - 50
