Brand
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad
Quicklinx: 8T5HWS00 Mfr#: USBLT1MW
Length: 1m
Colours:
More than 50 in stock
£13.64 ex VAT
£16.36 inc VAT
Charge and Sync your Apple Lightning-equipped devices. The USBLT1MW 1m White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable - 1 meter (USBLT1MW) - Lightning cable - Lightning / USB - 1 m
Cable
Double shielded
American Wire Gauge (AWG)
24/28
Length
1 m
White
Connector
Lightning - male
Connector (Second End)
USB - male
Sync and charge
P/N: BOX4HDECP, BOX4HDECP2, KITBXAVHDPNA, KITBXDOCKPNA, KITBZDOCK, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, ST43004UA, ST4300MINI, ST7C51224, ST7C51224EU, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
Cable Type
Lightning cable
Interface Supported
Lightning / USB
Double shielded
24/28
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Sync and charge
White
Connector
Apple Lightning - male
4 pin USB Type A - male
RoHS
8T5H StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.69
8T5H StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F In Stock £4.23
8T5H StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £3.98
8T5H StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.08
8T5H StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub In Stock £92.45
8T5H StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F In Stock £3.30
8T5H StarTech.com USB 3.0 Front Panel 4 Port Hub – 3.5in or 5.25in Bay In Stock £42.83
8T5H StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 In Stock £38.09
8T5H StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad In Stock £13.64
8T5H StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F In Stock £5.94
8T5H StarTech.com 2m White USB 2.0 Extension Cable A to A - M/F In Stock £5.51
8T5H StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) In Stock £51.42
8T5H StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black In Stock £46.11
8T5H StarTech.com Dual Port Car Charger with Apple 8-pin Lightning Connector and USB 2.0 Port In Stock £26.36
8T5H StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £14.20
8T5H StarTech.com 7 Port USB 3.0 Hub Desktop In Stock £58.00
8T5H StarTech.com Car Charger - Micro USB & USB In Stock £12.44
8T5H StarTech.com Car Charger - Micro USB & USB In Stock £10.25
8T5H StarTech.com Car Charger - Lightning & USB In Stock £26.64
8T5H StarTech.com 7 Port Industrial USB 3.0 Hub In Stock £107.01
8T5H StarTech.com 2x USB Wall Charger 17W / 3.4A In Stock £14.84
8T5H StarTech.com 10 Port Industrial USB 3.0 Hub In Stock £123.11
8T5H StarTech.com 10-Pt USB 3.0 Hub w/ Charging In Stock £61.95
8T5H StarTech.com 4-Port USB 3 Hub + 2.4A DCP In Stock £40.54
8T5H StarTech.com 7-Pt USB 3.0 Hub + Charge Pts In Stock £55.34
8T5H StarTech.com 2x USB Car Charger 24W / 4.8A In Stock £11.44
8T5H StarTech.com 4 Port USB 3.0 Hub with USB C In Stock £41.66
8T5H StarTech.com 4PT USB 3.0 Hub - Charge Port In Stock £27.68
Length: 1m
Stock Status: In stock
