Charge and Sync your Apple Lightning-equipped devices. The USBLT1MW 1m White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- Startech 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable - 1 meter (USBLT1MW) - Lightning cable - Lightning / USB - 1 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/28
- Cable Length
- 1 m
- White
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- 2-year warranty
- Designed For
- P/N: BOX4HDECP, BOX4HDECP2, KITBXAVHDPEU, KITBXAVHDPNA, KITBXAVHDPUK, KITBXDOCKPEU, KITBXDOCKPNA, KITBXDOCKPUK, KITBZDOCK, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, ST43004UA, ST4300MINI, ST7C51224, ST7C51224EU, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 24/28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Cable Length
- 1 m
- Plated Connector
- Nickel
- Sync and charge
- White
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- RoHS
- Limited warranty - 2 years
- Designed For
StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £5.29 |
StarTech.com 10ft USB 2.0 Extension Cable A to A - M/F | In Stock | £5.00 |
StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.06 |
StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F | In Stock | £4.19 |
StarTech.com Mountable 4 Port Rugged Industrial SuperSpeed USB 3.0 Hub | In Stock | £101.41 |
StarTech.com 6in USB 2.0 Extension Adapter Cable A to A - M/F | In Stock | £4.92 |
StarTech.com 6 Port USB 3.0 / USB 2.0 Combo Hub with 2A Charging Port – 2x USB 3.0 & 4x USB 2.0 | In Stock | £38.96 |
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad | In Stock | £14.23 |
StarTech.com 2m (6ft) Long White Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad | In Stock | £15.14 |
StarTech.com 3m White USB 2.0 Extension Cable A to A - M/F | In Stock | £6.37 |
StarTech.com 4 Port USB 3.0 Hub plus 3 Dedicated USB Charging Ports (2 x 1A & 1 x 2A) | In Stock | £24.95 |
StarTech.com 7 Port SuperSpeed USB 3.0 Hub - Desktop USB Hub with Power Adapter – Black | In Stock | £48.45 |
StarTech.com USB Wall Charger 17W / 3.4A x2 | In Stock | £15.09 |
StarTech.com 7 Port USB 3.0 Hub Desktop | In Stock | £62.29 |
StarTech.com 7 Port Industrial USB 3.0 Hub | In Stock | £108.59 |
StarTech.com 2x USB Wall Charger 17W / 3.4A | In Stock | £14.91 |
StarTech.com 10 Port Industrial USB 3.0 Hub | In Stock | £128.27 |
StarTech.com 10-Pt USB 3.0 Hub w/ Charging | In Stock | £64.21 |
StarTech.com 7-Pt USB 3.0 Hub + Charge Pts | In Stock | £56.18 |
StarTech.com 2x USB Car Charger 24W / 4.8A | In Stock | £12.51 |
StarTech.com 4 Port USB 3.0 Hub with USB C | In Stock | £39.49 |
StarTech.com 4PT USB 3.0 Hub - Charge Port | In Stock | £31.05 |
