StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M
Quicklinx: 8WSKWS00 Mfr#: USB3CAUB1M
£9.41 ex VAT
£11.29 inc VAT
Connect your Micro-B USB 3.0 devices, with this high-quality USB 3.0 certified cable. The USB3CAUB1M 1m USB 3.0 Micro B cable provides a high quality connection between your Micro USB-equipped USB 3.0 devices (e.g. card reader, video capture device, hard drive enclosure, etc.) and a USB-capable computer.
This cable is USB-IF certified to USB 3.0 specifications, guaranteeing a dependable, long-lasting connection to your Micro USB devices.
  • Fast data transfer speed
    With a data rate of 5 Gbps, this cable allows for quick and efficient file transfers between devices, minimizing downtime.
  • Durable construction
    The use of nickel-plated connectors ensures that the cable maintains a strong connection and withstands frequent use without wear.
  • Versatile connectivity
    Featuring a 10 pin Micro-USB Type-B connector and a 9-pin USB Type-A connector, this cable allows for compatibility with various devices.
  • Environmentally conscious design
    This cable complies with RoHS standards, reflecting a commitment to minimizing harmful substances and promoting environmental health.
  • Reliable shielding technology
    The cable's shielded design protects against interference, ensuring stable and consistent performance during data transfers.
StarTech.com 1m 3 ft Certified SuperSpeed USB 3.0 A to Micro B Cable Cord - USB 3 Micro B Cable - 1x USB A (M), 1x USB Micro B (M) - Black (USB3CAUB1M) - USB cable - Micro-USB Type B to USB Type A - 1 m
USB cable
Shielded
5 Gbps data rate
Length
1 m
Connector
10 pin Micro-USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB 3.0
P/N: DKT30CVAGPD, HB30A4AIB, HB30AM4AB, HB30C4AIB, HB31C2A2CME, HB31C3A1CME, HB31C4AB, HBS304A24A, S2510BPU337, S251BU31REM, S251BU31REMD, S251SMU33EP, ST7C51224, ST7C51224EU, ST7CU35122
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
5 Gbps data rate
Length
1 m
Connector
USB 3.0, RoHS
8WSK StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £9.84
8WSK StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
8WSK StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M In Stock £9.41
