Charge and sync your Apple Lightning-equipped devices, even when inside a protective case. The USBLT1MBS 1m Slim Lightning to USB Cable is colored to suit black iPhone, iPod, and iPad mobile devices and provides a reliable solution for charging and syncing your Apple devices with your PC or Mac computer, through an available USB port.
The cable offers a slim Lightning connector housing which plugs into your device even while it is inside a protective case, so you won't have the hassle of constantly removing the cover each time you charge or sync. Plus, the reversible 8-pin connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This lightweight cable also provides a portable solution that makes it perfect for carrying as a laptop or iPad accessory.
The USBLT1MBS is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
- StarTech.com 3 ' / 1m USB Lightning Cable for iPhone iPod iPad - Black - Discontinued, Limited Stock, Replaced by RUSBLTMM1MB (USBLT1MBS) - Lightning cable - Lightning / USB - 1 m
- Cable
- Technology
- Shielded
- American Wire Gauge (AWG)
- 24/32
- Length
- 1 m
- Black
- Connector
- Lightning - male
- Connector (Second End)
- USB - male
- Sync and charge
- 2-year warranty
- Designed For
- P/N: ST1030USBM
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Technology
- Shielded
- 24/32
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 1 m
- Plated Connector
- Nickel
- Sync and charge
- Black
- Connector
- Apple Lightning - male
- 4 pin USB Type A - male
- RoHS
- Limited warranty - 2 years
- Designed For
- P/N: ST1030USBM
