StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k
Quicklinx: 84MPWS00 Mfr#: MDPMM1MW
Length: 1m
£12.15 ex VAT
£14.58 inc VAT
Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and monitor. The MDPMM1MW 1m White Mini DisplayPort 1.2 cable features 2 Mini DP male connectors, and offers a dependable solution for connecting any Mini DisplayPort-enabled laptop (including Mac family of products) to a Mini DisplayPort-equipped monitor.
The mDP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
StarTech.com 1m 3ft White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k w/ HBR2 support - Mini DP to Mini DP Cable 1 meter, 3 feet (MDPMM1MW) - DisplayPort cable - 1 m
DisplayPort cable
Shielded
Drain wire
Length
1 m
Connector
Mini DisplayPort - male
Connector (Second End)
RoHS
White
P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP
DisplayPort cable
Shielded
Shielding Material
Aluminum mylar foil
American Wire Gauge (AWG)
32
Plated Connector
Gold
Drain wire
Length
1 m
White
Connector
RoHS
84MP StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.73
84MP StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £14.18
Length: 1m
