Create a high-resolution 4k x 2k connection with HBR2 support between your Mini DisplayPort-equipped laptop and monitor. The MDPMM1MW 1m White Mini DisplayPort 1.2 cable features 2 Mini DP male connectors, and offers a dependable solution for connecting any Mini DisplayPort-enabled laptop (including Mac family of products) to a Mini DisplayPort-equipped monitor.
The mDP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Newer laptop and desktop computers (e.g. Apple) come equipped with Thunderbolt ports only. The Mini DisplayPort Cables can be connected to the Thunderbolt ports, enabling you to connect your Mini DP compatible displays.
- StarTech.com 1m 3ft White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k w/ HBR2 support - Mini DP to Mini DP Cable 1 meter, 3 feet (MDPMM1MW) - DisplayPort cable - 1 m
- DisplayPort cable
- Technology
- Shielded
- Drain wire
- Length
- 1 m
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- RoHS
- White
- Limited lifetime warranty
- Designed For
- P/N: CDP2MDP, CDP2MDPEC, CDP2MDPFC, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDMDP
- DisplayPort cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Gold
- Drain wire
- Length
- 1 m
- White
- Connector
- RoHS
- Designed For
StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £10.43 |
StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £12.74 |
StarTech.com 3m (10 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k | In Stock | £15.35 |
StarTech.com 1m (3 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £14.48 |
StarTech.com 2m (6 ft) White Mini DisplayPort 1.2 Cable M/M - Mini DisplayPort 4k | In Stock | £16.38 |
StarTech.com 3m (10 ft) White Mini DisplayPort Cable - M/M | In Stock | £17.45 |
