This angled USB to Lightning cable withstands the demands of charging and syncing your mobile devices. Tested for strenuous wear and tear, the Lightning cable's angled connector gives you easy access to your mobile device even while charging.
With Kevlar aramid fiber reinforcement, the durable Lightning cable is sheltered from the stress of frequent bends and twists, which allows the cable to flex without over-stretching.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil and braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable.
Constructed to prevent the connector from separating from the cable jacket, the extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. Lightning connector provides 12W for charging your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180-degree angle.
Built for daily use
With aramid fiber reinforcement, the durable Lightning cable is sheltered from the stress of frequent bends and twists, which allows the cable to flex without over-stretching. -
Right-angled connector
90-degree connector eliminates tension and protects the lightning port of a device. Ideal for car mounts, classroom desk mounts or mounted POS. -
Apple MFi-certified
Fast and reliable charge from USB-A charger/port to Lightning devices.
- StarTech.com 3ft (1m) Durable USB A to Lightning Cable, Black 90° Right Angled Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charging/Sync Cord, Apple MFi Certified, iPhone 12 Pro - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB - 1 m
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 22/32
- Length
- 1 m
- Black
- Connector
- Lightning - male - angled
- Connector (Second End)
- USB - male
- USB / USB 2.0
- Strain relief
- 2-year warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 22/32
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- USB / USB 2.0
- Length
- 1 m
- Plated Connector
- Nickel
- Strain relief
- Black
- Connector
- Apple Lightning - male - angled
- 4 pin USB Type A - male
- RoHS, REACH, MFI, EMI
- 2.61 cm
- 0.7 cm
- 15 g
- Shipping Width
- 7.5 cm
- Shipping Depth
- 14.5 cm
- Shipping Height
- 1.7 cm
- Shipping Weight
- 100 g
- Limited warranty - 2 years
StarTech.com 1m USB to Lightning Cable | In Stock | £12.30 |
StarTech.com 1m USB to Lightning Cable - Black | In Stock | £12.30 |
