This rugged 1ft (30cm) USB-C right angle cable can be used to connect and/or charge a USB peripheral. Conveniently connect USB-C enabled devices at a right angle to the cable for organized cable routing solutions.
Built for Daily Use
The durable USB charging cable features aramid fiber reinforcement that protects the cable from the stress of frequent bends. This allows the cable to flex without over-stretching or damaging the core components of the cable. -
Flexible Strain Reliefs
The USB cable has been designed to prevent cable/connector strain. The extra-long strain relief moldings have been tested to withstand over 5,000+ bend cycles at a 180° angle. -
Superior Connection Quality
The durable cable supports all USB specifications up to USB 2.0, providing a dependable connection for USB-C peripheral devices. It supports up to 3A for charging USB-C-enabled devices. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 1ft (30cm) USB C Charging Cable Right Angle, 60W PD 3A, Heavy Duty Fast Charge USB-C Cable, USB 2.0 Type-C, Durable and Rugged Aramid Fiber, S20/iPad/Pixel - High Quality USB Charging Cord (R2CCR-30C-USB-CABLE) - USB-C cable - 24 pin USB-C to 24 pin USB-C - 30 cm
- USB-C cable
- Technology
- Shielded
- Sync and charge, strain relief, halogen free, heavy duty, up to 60 Watts of power delivery, Quick Charge
- Length
- 30 cm
- Connector
- 24 pin USB-C - male - straight
- Connector (Second End)
- 24 pin USB-C - male - right-angled
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C cable
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- American Wire Gauge (AWG)
- 22/32
- Rated Current
- 3 A
- Plated Connector
- Gold, nickel
- Length
- 30 cm
- Outside Diameter
- 3.1 mm
- Black
- 10 g
- Connector
- USB / USB 2.0, RoHS, WEEE, EMI
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 10.8 g
StarTech.com USB A to USB C Charging Cable | In Stock | £6.10 |
StarTech.com 3ft USB A to USB C Charging Cable | In Stock | £6.84 |
StarTech.com 6ft USB A to USB C Charging Cable | In Stock | £9.17 |
StarTech.com 6in USB C Charging Cable | In Stock | £6.38 |
StarTech.com 3ft USB C Charging Cable | In Stock | £8.53 |
StarTech.com 6ft USB C Charging Cable | In Stock | £9.90 |
