StarTech.com 1ft DisplayPort 1.4 8K 60Hz
Quicklinx: J1K3WS00 Mfr#: DP14VMM1F
35 In Stock
£10.15 ex VAT
£12.18 inc VAT
The StarTech.com 1ft/30cm DisplayPort 1.4 Cable is a premium solution for connecting your DisplayPort-enabled devices. Supporting 8K 60 Hz HDR10, it delivers exceptional visual quality and lifelike colors, making it suitable for professional and home entertainment setups. The cable's durable thermoplastic elastomer (TPE) jacket ensures it can withstand daily use, while its compact length makes it perfect for setups where space is limited. With male connectors on both ends, it offers hassle-free connectivity, eliminating the need for additional adapters. Whether you're gaming, streaming, or working, this DisplayPort 1.4 cable is designed to provide a superior display experience.
  • High-resolution support
    Experience the future of display technology with the StarTech.com DisplayPort 1.4 cable, enabling 8K 60 Hz HDR10 performance for lifelike colors and a stunning visual experience.
  • Durable design
    Constructed with a thermoplastic elastomer (TPE) jacket, this cable is designed for both flexibility and durability, ensuring it withstands the rigors of daily use while maintaining peak performance.
  • Universal connectivity
    Featuring a male connector on both ends, this cable offers versatile connectivity options, making it easy to connect a wide range of DisplayPort-enabled devices without the need for additional adapters.
StarTech.com 1ft/30cm DisplayPort 1.4 Cable, 8K 60Hz HDR10 - DisplayPort cable - DisplayPort to DisplayPort - 30 cm
DisplayPort cable
Shielded
Halogen-free, molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, HDR10 support, corrosion-resistant connectors, strain relief, EMI protection, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, High Bit Rate 3 (HBR3), 7.1 audio channel support, 5000+ bend lifespan, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 19 conductors, 5.1 audio channel support, daisy-chaining
Length
30 cm
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
34
Plated Connector
Gold
Length
30 cm
Outside Diameter
4.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, WEEE, HDCP 2.2
Shipping Width
22 cm
Shipping Depth
20 cm
Shipping Height
2 cm
Shipping Weight
18.5 g
