Charge your iPad or iPhone inside its car mount. This coiled Lightning cable delivers the compact convenience you need to keep your mobile devices charged while you're driving, without cluttering up your car.
Simply plug the cable into your USB car charger and stretch it out to connect your mobile device when you need to charge it. You can extend the cable up to 1 ft (0.3m), to comfortably reach your car-mounted tablet or phone.
When you're not charging your mobile device, you can neatly store this compact cable in your car's storage console or glove box. Plus, it's portable enough to keep it in your laptop bag or carrying case, so you can have it handy when you arrive at your destination and use it as a conventional charge-and-sync cable.
The USBCLT30CMW coiled Lightning cable is Apple MFi certified.
- StarTech.com Lightning to USB Cable - Coiled Lightning Cable - 0.3m (1ft) - White - Apple MFi Certified (USBCLT30CMW) - Lightning cable - Lightning / USB - 30 cm
- Cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28/30
- Length
- 30 cm
- White
- Connector
- USB - male
- Connector (Second End)
- Lightning - male
- Coiled
- 2-year warranty
- Cable Type
- Lightning cable
- Interface Supported
- Lightning / USB
- Technology
- Double shielded
- 28/30
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 30 cm
- Plated Connector
- Nickel
- Coiled
- White
- Connector
- 4 pin USB Type A - male
- Apple Lightning - male
- RoHS
- Limited warranty - 2 years
