The 1 ft (30 cm) USB to Serial Adapter Cable from StarTech.com provides a reliable connection for various applications requiring serial communication. With high-quality construction featuring copper shielding, this adapter cable ensures EMI/RFI protection and electrostatic discharge (ESD) protection, allowing for stable data transfers without interference. The cable is designed with a molded, rugged build, suitable for both casual and professional use.
Equipped with a LED status indicator, users can easily monitor connection status, while the FTDI FT232R chipset assures compatibility with a wide array of devices. The bus-powered capability ensures simplicity and convenience, as no external power supply is needed. The DB-9 male connector features a screwable design to secure connections, making it an excellent choice for reliable serial connections in various environments.
Durable construction
This USB to Serial Adapter Cable features a rugged molded design that ensures longevity and reliability, making it suited for both home and professional use. -
Effective shielding
The cable is constructed with copper shielding which provides EMI/RFI protection and electrostatic discharge (ESD) protection, allowing for stable and interference-free data transfer. -
Status indicator
An integrated LED status indicator allows users to easily monitor the connection status, enhancing usability and troubleshooting. -
Secure connections
The screwable design of the DB-9 male connector ensures that connections remain secure, reducing the risk of disconnection during use. -
Chipset compatibility
Utilizing the FTDI FT232R chipset, this adapter cable offers compatibility with various devices, making it versatile for different applications.
- StarTech.com 1ft (30cm) USB to Serial Adapter Cable, COM Retention, RS232 - USB / serial cable - USB to DB-9 - 30.5 cm
- Technology
- Shielded
- Rugged, molded, Chipset FTDI FT232R, electrostatic discharge (ESD) protection, LED status indicator, EMI/RFI protection, COM retention, bus powered
- Length
- 30.5 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - male - screwable
- USB 2.0 / USB 1.1
- 2-year warranty
- Technology
- Shielded
- Shielding Material
- Copper
- Plated Connector
- Gold
- Length
- 30.5 cm
- 30 g
- Connector
- Included Accessories
- Db9 connector nuts
- USB 2.0 / USB 1.1, RoHS, RS-232
- Shipping Width
- 22 cm
- Shipping Depth
- 30 cm
- Shipping Height
- 1.6 cm
- Shipping Weight
- 35 g
- 2-year warranty
