StarTech.com 1ft/30cm USB to Serial Adapter
Quicklinx: J1LVWS00 Mfr#: 1P1FFC-USB-SERIAL
Length: 30.5cm
11 In Stock
£23.82 ex VAT
£28.58 inc VAT
The 1 ft (30 cm) USB to Serial Adapter Cable from StarTech.com provides a reliable connection for various applications requiring serial communication. With high-quality construction featuring copper shielding, this adapter cable ensures EMI/RFI protection and electrostatic discharge (ESD) protection, allowing for stable data transfers without interference. The cable is designed with a molded, rugged build, suitable for both casual and professional use.
Equipped with a LED status indicator, users can easily monitor connection status, while the FTDI FT232R chipset assures compatibility with a wide array of devices. The bus-powered capability ensures simplicity and convenience, as no external power supply is needed. The DB-9 male connector features a screwable design to secure connections, making it an excellent choice for reliable serial connections in various environments.
  • Durable construction
    This USB to Serial Adapter Cable features a rugged molded design that ensures longevity and reliability, making it suited for both home and professional use.
  • Effective shielding
    The cable is constructed with copper shielding which provides EMI/RFI protection and electrostatic discharge (ESD) protection, allowing for stable and interference-free data transfer.
  • Status indicator
    An integrated LED status indicator allows users to easily monitor the connection status, enhancing usability and troubleshooting.
  • Secure connections
    The screwable design of the DB-9 male connector ensures that connections remain secure, reducing the risk of disconnection during use.
  • Chipset compatibility
    Utilizing the FTDI FT232R chipset, this adapter cable offers compatibility with various devices, making it versatile for different applications.
StarTech.com 1ft (30cm) USB to Serial Adapter Cable, COM Retention, RS232 - USB / serial cable - USB to DB-9 - 30.5 cm
USB / serial cable
Shielded
Rugged, molded, Chipset FTDI FT232R, electrostatic discharge (ESD) protection, LED status indicator, EMI/RFI protection, COM retention, bus powered
Length
30.5 cm
Connector
4 pin USB Type A - male
Connector (Second End)
9 pin D-Sub (DB-9) - male - screwable
USB 2.0 / USB 1.1
USB / serial cable
Shielded
Shielding Material
Copper
Plated Connector
Gold
Length
30.5 cm
30 g
Connector
Db9 connector nuts
USB 2.0 / USB 1.1, RoHS, RS-232
Shipping Width
22 cm
Shipping Depth
30 cm
Shipping Height
1.6 cm
Shipping Weight
35 g
Length: 30.5cm
