StarTech.com 18U Server Rack Cabinet
Quicklinx: CZD1WS00 Mfr#: RK1833BKM
Depth (mm): 85.3cm
Width (mm): 60cm
£421.07 ex VAT
£505.28 inc VAT
Securely store servers, network and telecommunications equipment in this 18U server or network cabinet. This server rack provides 18U of storage space in a sleek, secure cabinet for storing standard 19" rack-mount devices such as Dell, HP, and IBM servers, along with telecommunication and A/V equipment. The rack is compatible with EIA-310 compliant equipment and supports a total load capacity of 450 kg (992 lb.).
This rack includes a variety of features that enable you to easily incorporate plenty of equipment. With adjustable mounting rails, you can easily change the rail depth from 3" up to 30.7" (76.2 mm - 780 mm) to ensure compatibility your standard rack-mount equipment. The added depth also provides support for additional cable and power management behind your equipment. For hassle-free cable management, the rack includes a 3 meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment.
The rack features holes with covers on the ceiling and floor panels that make it easy to run cabling to the inside and outside of the cabinet, for discreet cable management. The rack also features grounding lugs that enable you to ground your equipment for added protection. This rack also includes a 1U shelf that gives you a stable surface for placing equipment that's not rack-mountable or storing your tools.
To provide hassle-free deployment the rack ships fully assembled.
To keep your rack-mounted equipment secure, this rack features front and rear locking mesh doors. The mesh doors look great in any server room and help provide passive cooling. The doors are also reversible, which gives you the freedom to choose which side of the rack the door opens from, to suit your server room's spatial requirements.
The rack also has removable side panels with independent quick-release locks that enable you to access your equipment easily, while still keeping it secure.
The cabinet features casters for hassle-free access to rear-mounted equipment while providing ease of mobility around your office, studio or server room. Plus, the width and height of the rack fit through standard doorways, giving you the freedom to wheel your server rack into different rooms.
  • Hassle-free equipment installation
    This rack includes a variety of features that enable you to easily incorporate plenty of equipment. With adjustable mounting rails, you can easily change the rail depth from 2" up to 30" (76.2 mm - 780 mm) to ensure compatibility your standard rack-mount equipment. The added depth also provides support for additional cable and power management behind your equipment. For hassle-free cable management, the rack includes a 3 meter roll of hook-and-loop cable tie that makes it easy to keep your cables neat and tidy by binding them together or binding them to the rack. The self-gripping fabric can be cut to any size, enabling a wrap-around solution for the cables of any rack-mount equipment. The rack features holes with covers on the ceiling and floor panels that make it easy to run cabling to the inside and outside of the cabinet, for discreet cable management. The rack also features grounding lugs that enable you to ground your equipment for added protection. This rack also includes a 1U shelf that gives you a stable surface for placing equipment that's not rack-mountable or storing your tools. To provide hassle-free deployment the rack ships fully assembled.
  • Securely protect your equipment
    To keep your rack-mounted equipment secure, this rack features front and rear locking mesh doors. The mesh doors look great in any server room and help provide passive cooling. The doors are also reversible, which gives you the freedom to choose which side of the rack the door opens from, to suit your server room's spatial requirements. The rack also has removable side panels with independent quick-release locks that enable you to access your equipment easily, while still keeping it secure.
  • Maximum Maneuverability, with casters included
    The cabinet features casters for hassle-free access to rear-mounted equipment while providing ease of mobility around your office, studio or server room. Plus, the width and height of the rack fit through standard doorways, giving you the freedom to wheel your server rack into different rooms. The RK1833BKM is backed by a StarTech.com 5-year warranty and free lifetime technical support.
StarTech.com 18U Server Rack Cabinet, 4-Post Adjustable Depth (2" to 30") Network Equipment Rack Enclosure w/Casters/Cable Management/Shelf/Locking Dell PowerEdge, HP ProLiant ThinkServer - 18U Rack Cabinet (RK1833BKM) - rack - 18U
Rack
Rack Type
Cabinet
Package Content
2 side panel keys, 2 door keys, fixed shelf, casters, loop, hook, 72 cage nuts, 72 mounting screws
Rack Size
31"
Height (Rack Units)
18U
Product Material
Aluminium, steel
60 cm x 85.3 cm x 90.3 cm
Mesh front door, mesh rear door, mesh side panels
5-year warranty
Rack
Rack Type
Cabinet
Product Material
Aluminium, steel
Package Content
Rack Size
31"
Height (Rack Units)
18U
60 cm
85.3 cm
90.3 cm
68.7 kg
Weight Limit
450 kg
Mounting Kit
Included
Limited warranty: - 5 years , Technical support: - lifetime
CZD1 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £96.93
CZD1 StarTech.com Universal VESA LCD Monitor Mounting Bracket for 19in Rack or Cabinet In Stock £46.41
CZD1 StarTech.com Adjustable Rackmount DIN Rail Kit with Top Hat/Mini/G Rails In Stock £84.93
CZD1 StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.34
CZD1 StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.51
CZD1 StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.10
CZD1 StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £477.22
CZD1 StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £335.92
CZD1 StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
CZD1 StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.56
CZD1 StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.09
CZD1 StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.23
CZD1 StarTech.com 1U 7in Depth Universal Fixed Rack Mount Shelf – 33lbs / 15kg In Stock £25.89
CZD1 StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £92.13
CZD1 StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £542.00
CZD1 StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £284.45
CZD1 StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.76
CZD1 StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £635.38
CZD1 StarTech.com 2U Adjustable Mounting Depth Vented Sliding Rack Mount Shelf – 50lbs / 22.7kg In Stock £86.73
CZD1 StarTech.com 4U Black Steel Storage Drawer for 19in Racks and Cabinets In Stock £101.34
CZD1 StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £63.29
CZD1 StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.90
CZD1 StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.04
CZD1 StarTech.com 1U Adjustable Mounting Depth Rack Mount Shelf - Heavy Duty Shelf - 175lbs / 80kg In Stock £73.91
CZD1 StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £82.73
CZD1 StarTech.com 2U 22in Depth Fixed Rack Mount Shelf - 50lbs / 22kg In Stock £55.31
CZD1 StarTech.com 2U 22in Vented Rack Mount Shelf – Fixed Server Rack Cabinet Shelf - 50lbs / 22kg In Stock £44.71
CZD1 StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £37.48
CZD1 StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £52.08
CZD1 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
CZD1 StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.36
CZD1 StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.45
CZD1 StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £39.94
CZD1 StarTech.com 2U Vented Sliding Rack Shelf w/ Cable Management Arm & Adjustable Depth 50lbs / 22.7kg In Stock £162.10
CZD1 StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
CZD1 StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.96
CZD1 StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.35
CZD1 StarTech.com 1U Server Rack Panel In Stock £11.99
CZD1 StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.09
CZD1 StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.44
CZD1 StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
CZD1 StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.46
CZD1 StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
CZD1 StarTech.com 50 Pkg M5 Cage Nuts In Stock £15.59
CZD1 StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £54.01
CZD1 StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £29.06
CZD1 StarTech.com 50 Pkg M5 Mounting Screws In Stock £16.04
CZD1 StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.99
CZD1 StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.75
CZD1 StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.29
CZD1 StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
CZD1 StarTech.com 19in Cable Management Panel In Stock £23.30
CZD1 StarTech.com 100ft. Hook and Loop Roll - Blue - Reusable In Stock £18.26
CZD1 StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.40
CZD1 StarTech.com Heavy Duty Casters for Server Racks/Cabinets - Set of 4 In Stock £36.91
CZD1 StarTech.com M6 Mounting Screws 50Pack In Stock £16.78
CZD1 StarTech.com 42U Server Rack Cabinet In Stock £1,283.14
Depth (mm): 85.3cm
Width (mm): 60cm
