StarTech.com 18U Server Rack Cabinet - Includes Casters and Leveling Feet
Quicklinx: FP9NWS00 Mfr#: RK1836BKF
Hurry, only 3 left in stock!
£480.37 ex VAT
£576.44 inc VAT
This 18U server rack cabinet provides plenty of storage space in a sleek secure cabinet for storing EIA-310 compliant 19 inch rackmount devices such as Dell, HP and IBM servers along with telecommunication, A/V and IT equipment.
  • Hassle-Free Equipment Installation
    This knock down server rack has been engineered with different features that enable you to easily incorporate plenty of equipment. With adjustable mounting rails you can easily change the rail depth to up to 32 in. (813 mm).
  • Securely Protect Your Equipment
    To ensure you have full visibility of your equipment while securely locking it up, this rack has a stylish glass window on the front door. The server rack with glass door also has removable side panels with independent lock with quick-release mechanisms that enable you to easily access your network equipment.
  • Maximum Maneuverability
    The server rack with wheels ensures hassle-free access to the rear mounted equipment, while providing ease of mobility around your office or server room. Once the network equipment enclosure is at the intended location you can stabilize it using the built-in leveling feet in floor standing applications.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. The RK1836BKF is backed by a lifetime StarTech.com warranty with free technical support.
StarTech.com 18U 19" Server Rack Cabinet, 4 Post Adjustable Depth (6-32")Locking Knock Down Network/Computer Equipment Enclosure, Mobile with Glass Door & Casters, HP ProLiant ThinkServer - Data Rack Enclosure (RK1836BKF) - rack - 18U
Rack
Rack Type
Cabinet - 4-post
Placing / Mounting
Floor-standing
Package Content
Phillips screwdriver, 2 casters, top panel, front door, rear door, 2 side panel keys, 2 door keys, 4 x levelling feet, 24 M6 cage nuts, 2 casters with locking device, 2 side panel and frame, 4 upper and lower beams, 2 bottom panel with cable management slot, bottom panel (solid), 8 plastic corner caps, 8 M8-20 hex screws, 8 M8 spring washers, 8 M4-10 flat head screws, 4 M6-12 hex screws, 6 M5-12 screws, M6 hex key, M8 hex key, 24 M6-12 Phillips screws, 24 M6 plastic cup washers, 16 M6-10 Phillips bolts, 2 door hinge pins
Rack Size
19"
Height (Rack Units)
18U
Product Material
Glass, steel
60 cm x 1 m x 93 cm
65 kg
Key lock, integrated cable management, flat pack, adjustable mounting rails
Rack
Rack Type
Cabinet
Rack Post Qty
4-post
Placing / Mounting
Floor-standing
Product Material
Glass, steel
Package Content
Rack Size
19"
Height (Rack Units)
18U
60 cm
1 m
93 cm
65 kg
102.2 cm x 118.5 cm x 30.8 cm / 70 kg
Inner Dimensions
59.6 cm x 99.41 cm
Weight Limit
800 kg
EIA-310-C, RoHS, REACH, ECA-310-E
Limited warranty: - lifetime
FP9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £94.63
FP9N StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
FP9N StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.24
FP9N StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
FP9N StarTech.com 22in Black Deep Sliding Server Rack Cabinet Shelf In Stock £91.54
FP9N StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £62.88
FP9N StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £72.65
FP9N StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £77.01
FP9N StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £15.50
FP9N StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £81.75
FP9N StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £51.38
FP9N StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
FP9N StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
FP9N StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £24.18
FP9N StarTech.com 19in Cable Management Panel In Stock £24.18
FP9N StarTech.com 25ft. Hook-and-Loop Cable Tie In Stock £4.31
FP9N StarTech.com 50ft. Hook-and-Loop Cable Tie In Stock £10.53
FP9N StarTech.com 100ft. Hook-and-Loop Cable Tie In Stock £17.69
FP9N StarTech.com Cable Lacing Bars - 2in Offset In Stock £56.70
FP9N StarTech.com M6 Rack Screws and Cage Nuts In Stock £15.08
FP9N StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.83
FP9N StarTech.com 1U Server Rack Rails with Adjustable Depth - 4 post In Stock £47.11
FP9N StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.75
FP9N StarTech.com 15U Server Rack Cabinet - Includes Casters and Leveling Feet In Stock £435.23
