StarTech.com 18in SATA Serial ATA Data and Power Combo Cable
Quicklinx: 3ZLKWS00 Mfr#: SATA18POW
Length: 45.7cm
Type: ATA
10 In Stock
£5.64 ex VAT
£6.76 inc VAT
Power your Internal SATA hard drive from an LP4 / Molex connector on your Power Supply. The SATA18POW SATA Data and Power Cable features a combination 22-pin SATA receptacle data and power connector as well as an Molex (LP4) power connector and SATA receptacle data connector, allowing you to create a conventional Serial ATA data connection to a computer while powering the drive through an LP4 connection to the computer power supply.
This high quality SATA power/LP4 adapter cable measures 18in, providing the flexibility required to position the SATA hard drive as needed within the computer case, while eliminating the expense of upgrading the computer power supply for the sake of SATA compatibility.
StarTech.com 18in SATA Serial ATA Data and Power Combo Cable - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Length
45.7 cm
Connectors
22 pin Serial ATA - receptacle
Connectors (Second End)
7 pin Serial ATA - receptacle , 4 PIN internal power - male
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, HSB100SATBK, PATA2SATA3, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SATABAY5BK, SATSASBAY3BK
Storage Cable Type
SATA cable
Interface Speed
Length
45.7 cm
Red
Connectors
RoHS
Length: 45.7cm
Type: ATA
