StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLLWS00 Mfr#: SATA18
Length: 45.8cm
Type: ATA
More than 50 in stock
£3.35 ex VAT
£4.02 inc VAT
This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA18 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 18in SATA Serial ATA Cable - SATA cable - 45.8 cm
SATA cable
Length
45.8 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
P/N: USB2SATAIDEU, PEXSAT31E1, SATSASBAY425, PEXSAT32, USB2SATAIDGB, BRACKET25SAT, HSB220SAT25B, SAT2510U2S, PEXSATA22I, SATABAY425BK, PEXSATA24E, USB2SATAIDE, PEXSAT2IDE2, SAT2510U2REM, PCISAT2IDE1, PCISATA4R1
Storage Cable Type
SATA cable
Length
45.8 cm
Connector
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port eSATA + 4 Port SATA PCI Express x4 SATA Controller Adapter Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card, 2.5in SATA External Hard Drive Enclosure for 3.5/5.25 Front Drive Bay, 2S1I PCI SATA IDE Combo Controller Adapter Card, 2S2I PCI Express SATA IDE Combo Controller Adapter Card, 4 Drive 2.5in Removable Mobile Rack SAS SATA Backplane, 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 4 Port PCI SATA RAID Controller Adapter Card, Extra 2.5in SATA Hard Drive Enclosure for SAT2510U2REM, USB 2.0 to SATA IDE Adapter
Length: 45.8cm
Type: ATA
Price Range Ex VAT: 0 - 50
