StarTech.com 18in SATA Serial ATA Cable
Quicklinx: 3ZLLWS00 Mfr#: SATA18
Hurry, only 3 left in stock!
£2.50 ex VAT
£3.00 inc VAT
This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA18 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
  • Reliable connection
    The cable features dual 7 pin female connectors which ensure a stable and effective connection to various Serial ATA devices.
  • Compact design
    With an 18 in length, this cable is designed to optimize space within the system, preventing unnecessary clutter while maintaining effective connectivity.
  • High-speed data transfer
    This Serial ATA cable supports fast data transfer speeds, crucial for efficient performance and seamless operation of connected devices.
StarTech.com 18in SATA Serial ATA Cable - 18in SATA Cable - 18 SATA Cable - 18in Serial ata Cable - SATA cable - 45.8 cm
SATA cable
Length
45.8 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, IDE2SAT25, PATA2SATA3, PEXSAT32, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, ST521PMINT, USB3SSATAIDE
Storage Cable Type
SATA cable
Length
45.8 cm
Connector
P/N: 10P6G-PCIE-SATA-CARD, 25S22M2NGFFR, 25SAT22MSAT, 25SAT35HDD, 2P6G-PCIE-SATA-CARD, 35S24M2NGFF, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, BRACKET25SAT, HSB220SAT25B, IDE2SAT25, PATA2SATA3, PEXSAT32, PEXSATA22I, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATPEX, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
