StarTech.com 18in Right Angle SATA Cable
Quicklinx: HHXYWS00 Mfr#: LSATA18RA1
Length: 46cm
Type: SATA
33 In Stock
£4.22 ex VAT
£5.06 inc VAT
This right angled latching SATA cable features a (straight) female Serial ATA connector as well as a right-angled (female) SATA connector, providing a simple connection to a Serial ATA drive even if space near the drive's SATA port is limited. The cable offers latching connectors, which ensure secure connections for SATA hard drives and motherboards that support this feature.
Once the right-angled SATA connector has been inserted into the drive's SATA data port, the shaft of the cable is seated flush with the rear panel of the drive, eliminating the clutter of excess cable at the connection point - an ideal solution for small or micro form factor computer cases. The right angled SATA cable features a thin, narrow construction that helps to improve airflow within the computer case; the cable features a rugged, yet flexible design that makes it easy to make the SATA connection as needed.
  • Efficient connectivity
    The 18in Latching SATA to Right Angle SATA Serial ATA Cable offers a reliable connection between your motherboard and storage drives. Its Serial ATA 150/300 interface speed ensures efficient data transfer, making it ideal for PC users looking to enhance their system's performance.
  • Enhanced durability
    Featuring a right angle connector, this cable is designed to fit in tight spaces, reducing the risk of bending and cable strain. The latching mechanism secures the cable in place, ensuring a stable connection and prolonging the lifespan of your components.
StarTech.com 18in Latching SATA to Right Angle SATA Serial ATA Cable - SATA cable - 46 cm
SATA cable
Interface Speed
Serial ATA 150/300
Latched, right-angled connector
Length
46 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
P/N: 25S22M2NGFFR, 25SAT22MSAT, BRACKET25X2, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXSAT32, S322M225R, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Length
46 cm
Red
Connector
HHXY StarTech.com 18" Serial ATA Cable w/R Angle In Stock £5.00
HHXY StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F In Stock £6.16
Length: 46cm
Type: SATA
