StarTech.com 18in Latching SATA Cable
Quicklinx: 4LTJWS00 Mfr#: LSATA18
Length: 46cm
Type: ATA
Hurry, only 1 left in stock!
£3.72 ex VAT
£4.46 inc VAT
SATA hard drive cable, with latching SATA connectors, for securely fastened hard drive installations. The LSATA18 SATA Cable features two latching 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 18in Latching SATA Cable - SATA cable - Serial ATA 150/300/600 - SATA (R) to SATA (R) - 1.5 ft - latched - red - LSATA18 - SATA cable - 46 cm
SATA cable
Interface Speed
Latched
Length
46 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXESAT322I, PEXMSATA3422, PEXMSATA343, PEXSAT32, PEXSAT34RH, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Latched
Length
46 cm
Red
Connector
RoHS
P/N: 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, DRW110SATBK, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, PEXESAT322I, PEXMSATA3422, PEXMSATA343, PEXSAT32, PEXSAT34RH, SATSASBP425, ST521PMINT, USB2SATAIDE, USB3SSATAIDE
Length: 46cm
Type: ATA
Price Range Ex VAT: 0 - 50
