StarTech.com 18in Internal 2 pin IDC Motherboard Header Cable – HDD LED Cable F/F
Quicklinx: 80H7WS00 Mfr#: IDC2PIN18
Connect your system LED panel status lights to your motherboard or hard drive controller. The IDC2PIN18, 18-inch Motherboard/HDD LED cable features two 2-pin header connectors, enabling you to connect your system LED panel status lights to your motherboard or hard drive controller.
StarTech.com Internal 2 pin IDC Motherboard Header Cable - HDD LED cable - 2 pin IDC to 2 pin IDC - 45.7 cm
HDD LED cable
Length
45.7 cm
Connector
2 pin IDC - female
Connector (Second End)
2 pin IDC - female
P/N: PEX4SFF8639
HDD LED cable
American Wire Gauge (AWG)
24
Length
45.7 cm
Connector
2 pin IDC - female
2 pin IDC - female
RoHS
P/N: PEX4SFF8639
80H7 StarTech.com 6in USB 2.0 Cable - USB A Female to USB Motherboard 4 Pin Header F/F In Stock £6.03
