StarTech.com 18in DVI-D Single Link Cable - M/M
Quicklinx: 6LBYWS00 Mfr#: DVIMM18IN
Type: DVI
Length: 46cm
25 in stock
£5.61 ex VAT
£6.73 inc VAT
Provides a high-speed, crystal-clear connection to your DVI digital devices, with a short 18in cable. The DVIMM18IN DVI-D Single Link cable features 2 male DVI (19-pin) connectors and offers 18 inches in cable length, making it perfect for shorter connections between your desktop or laptop computer and a DVI-D monitor or projector.
The 18in DVI-D male to male cable supports resolutions of up to 1920x1200 and transmission rates of up to 4.95 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 18in DVI-D Single Link Cable - Male to Male DVI-D Digital Video Monitor Cable - DVI-D M/M - Black 18 inch - 1920x1200 (DVIMM18IN) - DVI cable - 46 cm
DVI cable
Length
46 cm
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
P/N: CDPVGDVHDBP
DVI cable
Length
46 cm
Connector
18+1 pin digital DVI (Single-Link) - male
P/N: CDPVGDVHDBP
Type: DVI
Length: 46cm
Price Range Ex VAT: 0 - 50
