Terminate Cat6 cables at a 180° angle, for a more compact keystone jack installation. The C6KEY110SWH Cat6 Keystone Jack is designed to snap into wall plates, patch panels, and surface connection boxes for quick, seamless deployment.
Meeting and exceeding the international standard ISO / IEC 11801 and the ANSI/TIA-568-C.2 requirements, this RJ45 keystone jack provides the perfect solution for your Ethernet networks.
 - StarTech.com 180 Degree Cat 6 Keystone Jack - RJ45 Ethernet Cat6 Wall Jack White - 110 Type - Keystone Jack 180 Degree 110 UTP (C6KEY110SWH) - keystone jack
- Product Type
 - Keystone jack - CAT 6 - RJ-45
 - 15.4 g
 - White
- Port Qty
 - 1 port
 - 2-year warranty
- Designed For
 - P/N: WIRC6CMPBLU
- Product Type
 - 15.4 g
- Enclosure Colour
 - White
Cabling & Wiring
- Port Qty
 - 1 port
- Termination Type
 - 110 type termination
 - Keystone type
- Connector Provided
 - 1 x RJ-45 female
 - Limited warranty - 2 years
- Designed For
 - P/N: WIRC6CMPBLU
