Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA18RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 18-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 18in Left Angle SATA cable (SATA18LA1), which provides the same simple installation as this right angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
- StarTech.com 18in SATA to Right Angle SATA Serial ATA Cable - 18in SATA Cable - 18 SATA Cable - 18in angled SATA Cable - SATA cable - 45.7 cm
- SATA cable
- Interface Speed
- Serial ATA 150/300/600
- Right-angled connector
- Length
- 45.7 cm
- Connector
- 7 pin Serial ATA - receptacle
- Connector (Second End)
- Red
- Limited lifetime warranty
- Designed For
- P/N: 25S22M2NGFFR, 25SAT22MSAT, 35S24M2NGFF, CFAST2SAT25, MSAT2SAT3, PATA2SATA3, PEXESAT322I, PEXMSATA3422, PEXMSATA343, PEXSAT34RH, S251BU31REM, S322M225R, S32M2NGFFPEX, SAT2M2NGFF25, SAT32M225, SAT32MSAT257, SAT32MSATM, SAT32MSATPEX, SATABAY5BK, ST521PMINT
- Storage Cable Type
- SATA cable
- Interface Speed
- Length
- 45.7 cm
- Red
- Connector
- RoHS
- Designed For
StarTech.com 24in SATA to Right Angle SATA Serial ATA Cable | In Stock | £3.98 |
StarTech.com 6in SATA Serial ATA Cable | In Stock | £3.35 |
StarTech.com 6in SATA to Right Angle SATA Serial ATA Cable | In Stock | £3.61 |
StarTech.com 36in SATA to Right Angle SATA Serial ATA Cable | In Stock | £4.68 |
StarTech.com 0.3m SATA Extension Cable | In Stock | £8.02 |
