StarTech.com 18" Serial ATA Cable w/R Angle
Quicklinx: 3ZLJWS00 Mfr#: SATA18RA1
Length: 45.7cm
Type: ATA
More than 50 in stock
£3.52 ex VAT
£4.22 inc VAT
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA18RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 18-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 18in Left Angle SATA cable (SATA18LA1), which provides the same simple installation as this right angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 18in SATA to Right Angle SATA Serial ATA Cable - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Right-angled connector
Length
45.7 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: PEXSATA24E, SATABAY5BK, SATATRAYBK, SATABAY3BK, SATABAY4BK, PCISATA4R1
Storage Cable Type
SATA cable
Interface Speed
Length
45.7 cm
Red
Connector
RoHS
StarTech.com 2 Port eSATA + 4 Port SATA PCI Express x4 SATA Controller Adapter Card, 3 Drive 3.5in SATA Hot Swap Hard Drive Backplane with RAID, 4 Drive 3.5in Hot Swap SATA Mobile Rack Backplane, 4 Port PCI SATA RAID Controller Adapter Card, Extra 3.5in Hot Swap Hard Drive Tray for SATA and SAS Backplanes
Length: 45.7cm
Type: ATA
Price Range Ex VAT: 0 - 50
