StarTech.com 17.3" Laptop Backpack w/ Case
Quicklinx: GXJSWS00 Mfr#: NTBKBAG173
Device Type: Laptop
Type: Backpack
Device Screen Size: 17.3
Colour: Black
£110.16 ex VAT
£132.19 inc VAT
17.3" Laptop Backpack with Removable Accessory Organizer Case - Professional IT Tech Backpack for Work/Travel/Commute - Ergonomic Computer Bag - Durable Ballistic Nylon - Notebook/Tablet Pockets (NTBKBAG173).
  • 17.3" Laptop Backpack
    This laptop backpack is designed and built with IT Professionals & Technicians in mind. For short or long-distance commutes, this travel-friendly IT backpack can carry your 17.3" laptop and tablet with you wherever you go. Equipped with an accessories case that can be easily removed and fits all of your IT accessories, including your laptop charger, display adapters, wireless mouse, tools, measurement instruments, and more. The laptop bag and accessory case are constructed of heavy-duty ballistic nylon to keep your items secure.
  • Removable Case for IT Accessories
    The removable travel accessories pouch (10.5in x 5.25in x 3in) is stored in its own compartment and was designed to be easily accessed using the lower side pocket of the backpack to avoid searching through or displacing other items. The hook and loop dividers can be adjusted or removed to suit your needs, and the bungee grid is perfect for storing smaller IT accessories and cables. With the case removed, the main compartment can be expanded to offer more room for any other essentials required for a short or long-term trip.
  • Ergonomic and Travel Friendly
    The computer bag features breathable ergonomic padding to help relieve strain and maximize comfort. It is designed for short distance (ie. daily commuting) and long-distance travel (ie. tradeshows and customer visits). The laptop bag features adjustable shoulder straps and a handle that is easy to grip. The laptop backpack meets most airline and TSA carry-on requirements and allows you to bundle your travel bags and rolling luggage using the integrated trolley sleeve.
  • Thoughtful Design
    There are a variety of practical pockets, including a velvet-lined pocket to store sensitive items, a pocket for water bottles, and a pocket on the shoulder strap (to keep your phone, passport, or work badge easily accessible), among others. This notebook backpack is backed by a StarTech.com limited lifetime warranty, and free lifetime technical support.
StarTech.com 17.3" Laptop Backpack with Removable Accessory Organizer Case - Professional IT Tech Backpack for Work/Travel/Commute - Ergonomic Computer Bag - Durable Ballistic Nylon - Notebook/Tablet Pockets - notebook carrying backpack
Notebook carrying backpack
Package Content
Cable, accessories pouch
Product Material
1680D ballistic nylon
20.3 cm x 32.4 cm x 46 cm
1.5 kg
Notebook Compatibility
17.3"
Padded back, padded notebook compartment, TSA friendly
Carrying Strap
Shoulder carrying straps, hook and loop strap, trolley sleeve
Checkpoint Friendly
Product Material
Package Content
20.3 cm
32.4 cm
46 cm
1.5 kg
20.3 cm x 32.4 cm x 46 cm / 1.5 kg
17.3"
Additional Compartments
Personal accessories, bottle, sunglasses, keys, tablet, internal mesh pockets, removable compartment
Checkpoint Friendly
Carrying Strap
Closure Type
Zipper
Ventilated Back
TSA
Limited warranty: - lifetime
GXJS StarTech.com 15.6" Laptop Backpack w/ Case In Stock £92.94
Device Type: Laptop
Type: Backpack
Colour: Black
