StarTech.com 16in MacBook Privacy Screen
Quicklinx: HDGBWS00 Mfr#: 16M21-PRIVACY-SCREEN
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 16
Colour: Transparent
£31.60 ex VAT
£37.92 inc VAT
This laptop privacy screen is compatible with the 2021 and 2023 16" MacBook Pro laptops.
  • Prevent Visual Eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your MacBook's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Reversible Filter
    The privacy screen protector is reversible, with a matte anti-glare side for environments prone to glare and a high-gloss side that helps retain color vibrancy. The matte side provides additional screen protection with a fingerprint and scratch resistant coating. The privacy shield has a light transmittance of 57.5% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    The privacy filter is an exact fit design that will not interfere with top-mounted webcams, sensors, or when closing the lid. Affix the privacy screen shield using the included transparent and residue-free adhesive strips.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort with this blue light reducing privacy shield. It blocks up to 51% of the blue light emitted from the display in the 380nm - 480nm wavelength range. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 16-inch MacBook Pro 21/23 Laptop Privacy Screen, Anti-Glare Privacy Filter with 51% Blue Light Reduction, Monitor Screen Protector with +/- 30 deg. Viewing Angle - Reversible Matte/Glossy Sides (16M21-PRIVACY-SCREEN) - notebook privacy filter (horizontal)
Notebook privacy filter (horizontal)
Package Content
Wiping cloth, 1 set of adhesive strips, sleeve, quick start guide
Transparent
Product Material
Plastic
35.1 cm 22.9 cm
100 g
Display Screen Size Compatibility
16"
Anti-glare, reversible, 51% blue light reduction, Hassle-free installation, fingerprint-resistant coating, +/- 30° visible angle
Apple MacBook Pro (16.2 in, Early 2023, Late 2021)
Product Material
Plastic
Package Content
35.1 cm
22.9 cm
Thickness
0.4 mm
100 g
38.5 cm x 24.5 cm x 2 mm / 190 g
16"
Transparent
Display Filter
Scratch Resistant
Limited warranty: - 2 years
HDGB StarTech.com Privacy Screen Adhesive Strips In Stock £6.41
Device Type: Laptop
Colour: Transparent
