StarTech.com 16in 9 Pin Serial Male to 10 Pin Motherboard Header Panel Mount Cable
Quicklinx: 7VXZWS00 Mfr#: PNL9M16
Length: 40.7cm
39 In Stock
£5.80 ex VAT
£6.96 inc VAT
Turn a Motherboard IDC Serial Header into a Panel-Mountable 9-Pin RS232 Serial Connector.
The PNL9M16 16-inch IDC Serial to Panel Mount Serial Cable, features a 10-pin (IDC) motherboard header connection on one end and a panel mount DB9 male connector port on the other - a simple answer for adding a DB9 (RS232) serial port to any computer system which has an RS232 serial panel mount receptacle.
This cost-effective solution bridges the compatibility gap between modern computers and legacy serial peripherals.
StarTech.com 16in 9 Pin Serial Male to 10 Pin Motherboard Header Panel Mount Cable - motherboard to RS232 (PNL9M16) - serial cable - DB-9 to 10 PIN IDC - 40.7 cm
Serial cable
Length
40.7 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Grey
Serial cable
American Wire Gauge (AWG)
28
Length
40.7 cm
Grey
Connector
10 PIN IDC - female
RoHS
7VXZ StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.93
7VXZ StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F In Stock £5.49
7VXZ StarTech.com 1 ft Panel Mount USB Cable B to B - F/M In Stock £6.60
7VXZ StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £9.49
7VXZ StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F In Stock £17.51
Length: 40.7cm
