Turn a Motherboard IDC Serial Header into a Panel-Mountable 9-Pin RS232 Serial Connector.
The PNL9M16 16-inch IDC Serial to Panel Mount Serial Cable, features a 10-pin (IDC) motherboard header connection on one end and a panel mount DB9 male connector port on the other - a simple answer for adding a DB9 (RS232) serial port to any computer system which has an RS232 serial panel mount receptacle.
This cost-effective solution bridges the compatibility gap between modern computers and legacy serial peripherals.
- StarTech.com 16in 9 Pin Serial Male to 10 Pin Motherboard Header Panel Mount Cable - motherboard to RS232 (PNL9M16) - serial cable - DB-9 to 10 PIN IDC - 40.7 cm
- Serial cable
- Length
- 40.7 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 10 PIN IDC - female
- Grey
- Limited lifetime warranty
- Serial cable
- American Wire Gauge (AWG)
- 28
- Length
- 40.7 cm
- Grey
- Connector
- RoHS
|  | StarTech.com 1 ft Panel Mount USB Cable A to A - F/M | In Stock | £4.92 |
|  | StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F | In Stock | £5.94 |
|  | StarTech.com 1 ft Panel Mount USB Cable B to B - F/M | In Stock | £5.67 |
|  | StarTech.com 3ft DisplayPort Panel Mount Cable - F/M | In Stock | £13.69 |
|  | StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M | In Stock | £9.34 |
|  | StarTech.com 3 ft 20 pin DisplayPort Extension Panel Mount Cable - M/F | In Stock | £15.06 |
