StarTech.com 16in 16:10 Laptop Touch Privacy Screen
Quicklinx: HM9RWS00 Mfr#: 16LT6-PRIVACY-SCREEN
Device Type: Laptop
Type: Privacy Screen
Device Screen Size: 16
Colour: Translucent black
17 In Stock
£31.22 ex VAT
£37.46 inc VAT
This Laptop Privacy Screen is designed to work with laptops with 16-inch displays and 16:10 aspect ratio.
  • Prevent visual eavesdropping
    This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user.
  • Flip-Up and Touch
    The feature enables you to quickly flip-up the privacy filter to share contents without uninstalling the filter. Your computer touch responsiveness is preserved by the ultrathin yet robust security shield, enabling seamless use. The privacy shield has a light transmittance of 60% providing optimal screen brightness and enhanced levels of privacy.
  • Hassle-free Installation
    Install the privacy screen protector using the included adhesive strips or flip-up tabs. This unit is designed for use with bezel-less or slim bezel displays.
  • Blue Light Reduction
    Reduce eye strain and improve visual comfort by reducing blue light exposure. The 16-inch laptop screen filter blocks up to 51% of the blue light emitted from the display. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
StarTech.com 16-inch 16:10 Touch Privacy Screen, Anti-Glare Privacy Filter, Laptop Monitor Screen Protector with +/- 30 Deg. View Angle, Flip-Up - 51% Blue Light Reduction (16LT6-PRIVACY-SCREEN) - notebook privacy filter
Notebook privacy filter
Installation Type
Adhesive, hinge tabs, flip hinges
Package Content
Adhesive strips, wiping cloth, mounting tabs, plastic sleeve, 2 flip-over tabs, lifting tab
38.3 cm x 21.5 cm
100 g
Display Screen Size Compatibility
16"
+/- 30° visible angle, 51% blue light reduction
Package Content
38.3 cm
21.5 cm
Thickness
1 mm
100 g
46.3 cm x 33 cm x 0.4 cm / 250 g
16"
Display Filter
Installation Type
Aspect Ratio
16:10
Mounting Kit
Included
Limited warranty: - 2 years
Device Type: Laptop
