This Laptop Privacy Screen is designed to work with laptops with 16-inch displays and 16:10 aspect ratio.
Prevent visual eavesdropping
This privacy filter is a convenient and cost-effective solution to protect confidential data from unwanted viewers. The privacy shield darkens your computer's screen from the side while providing a clear viewing angle of 60 degrees (+/- 30 degrees from center) to the user. -
Flip-Up and Touch
The feature enables you to quickly flip-up the privacy filter to share contents without uninstalling the filter. Your computer touch responsiveness is preserved by the ultrathin yet robust security shield, enabling seamless use. The privacy shield has a light transmittance of 60% providing optimal screen brightness and enhanced levels of privacy. -
Hassle-free Installation
Install the privacy screen protector using the included adhesive strips or flip-up tabs. This unit is designed for use with bezel-less or slim bezel displays. -
Blue Light Reduction
Reduce eye strain and improve visual comfort by reducing blue light exposure. The 16-inch laptop screen filter blocks up to 51% of the blue light emitted from the display. Digital eye strain can lead to symptoms like headaches, dry eyes, and blurred vision.
- StarTech.com 16-inch 16:10 Touch Privacy Screen, Anti-Glare Privacy Filter, Laptop Monitor Screen Protector with +/- 30 Deg. View Angle, Flip-Up - 51% Blue Light Reduction (16LT6-PRIVACY-SCREEN) - notebook privacy filter
- Product Type
- Notebook privacy filter
- Installation Type
- Adhesive, hinge tabs, flip hinges
- Package Content
- Adhesive strips, wiping cloth, mounting tabs, plastic sleeve, 2 flip-over tabs, lifting tab
- 38.3 cm x 21.5 cm
- 100 g
- Display Screen Size Compatibility
- 16"
- +/- 30° visible angle, 51% blue light reduction
- 2-year warranty
- Product Type
- Package Content
- 38.3 cm
- 21.5 cm
- Thickness
- 1 mm
- 100 g
- Shipping Dimensions (WxDxH) / Weight
- 46.3 cm x 33 cm x 0.4 cm / 250 g
- 16"
Display Filter
- Installation Type
- Aspect Ratio
- 16:10
- Mounting Kit
- Included
- Limited warranty: - 2 years
StarTech.com Privacy Screen Adhesive Strips | In Stock | £6.19 |
