StarTech.com 16ft DisplayPort 1.4 8K 60Hz
Quicklinx: GJJXWS00 Mfr#: DP14VMM5M
Length: 5m
11 In Stock
£35.05 ex VAT
£42.06 inc VAT
VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HDR10 - 16.4 ft. (5 m).
  • High performance
    VESA certified DisplayPort 1.4 cable; 8K 60Hz, 4K 120Hz, 32.4Gbps bandwidth, HDR10, 32Ch audio, MST, GTC for precise audio channel timing; future-proof your equipment by making it 8K ready.
  • Reliable
    28 AWG video cable built with internal wire manager to ensure signal integrity; metal connector sub-structure & Al-Mylar Foil w/Braid for superior EMI shielding; Gold-plated latching DP connectors prevent accidental disconnection,
  • Durable
    Tested to withstand 5000+ insertions and 300+ bend cycles at 120° angle; long lasting TPE jacket w/ molded Soft TPE strain relief absorbs stress of frequent bends; TPE is non-toxic, halogen free & RoHS certified for environmental sustainability.
StarTech.com 16ft (5m) VESA Certified DisplayPort 1.4 Cable, 8K 60Hz HDR10, Ultra HD 4K 120Hz DP Video Cable, DisplayPort to DisplayPort Cable, DP Cord for Monitors/Displays, M/M - DP 1.4 Cable with Latches (DP14VMM5M) - DisplayPort cable - DisplayPort to DisplayPort - 5 m
DisplayPort cable
Shielded
Molded, passive cable, 8K60Hz (7680 x 4320) support, 4K120Hz (3840 x 2160) support, strain relief, HBR3 support, Display Stream Compression 1.2 (DSC), DisplayPort Multi-Stream Transport (MST), 32 audio channels, HDR10 support, 7.1 audio channel support, Chroma subsampling (4:4:4), 32.4 Gbps data rate, Forward Error Correction, 5.1 audio channel support
Length
5 m
Connector
20 pin DisplayPort - male
Connector (Second End)
DisplayPort 1.4
Grey, black
DisplayPort cable
Shielded
Shielding Material
Jacket Material
Thermoplastic elastomer (TPE)
American Wire Gauge (AWG)
28
Plated Connector
Gold
Length
5 m
Outside Diameter
7.5 mm
Grey, black
Connector
DisplayPort 1.4, RoHS, HDCP 2.2, 8K VESA certified
Shipping Width
33 cm
Shipping Depth
25.5 cm
Shipping Height
2 cm
Shipping Weight
405 g
Length: 5m
