StarTech.com 16ft/5m Premium Certified HDMI 2.0 Cable
Quicklinx: GXT0WS00 Mfr#: HDMMV5M
Length: 5m
Hurry, only 2 left in stock!
£17.69 ex VAT
£21.22 inc VAT
HIGH PERFORMANCE CABLE: 16.4ft (5m) Premium Certified High-Speed HDMI cable with Ethernet supports 4K 60Hz (3840x2160), 18Gbps bandwidth, HDR10, Ultra-wide aspect ratio, ARC, 3D video, 32 Ch audio (5.1/7.1/Dolby TrueHD/Atmos), BT.2020 colorimetry.
PREMIUM HDMI 2.0 CABLE: Ultra HD 4K 60Hz HDMI cord is engineered and built to improve signal integrity - Featuring connector bodies encased in die-cast aluminum to prevent EMI induced signal degradation; Corrosion-resistant gold-plated connectors.
DURABLE: Tested to withstand 10,000+ insertions and 600+ bend cycles at 120° angle - Durable TPE jacket with soft molded TPE strain reliefs counters the stress of frequent bends - TPE is non-toxic and halogen free.
APPLICATIONS: Ideal for home/office, works with computer/laptop/desktop/PC/workstation - UHD HDMI cord to connect TV/monitor/display/projector, Samsung/Sony/Apple TV/Dell/LG - Works w/ HDMI 2.0 Ultra HD, and other resolutions.
SPECS: 16.4 feet (5 meter) - HDMI 2.0 - Premium Certified HDMI Cable - High-Speed Cable with Ethernet - Color: Gray and Black - HDMI Male to Male - Outer Diameter: 0.25" (6.5 mm) - 28 AWG - Jacket: TPE - EMI Shield: Al-Mylar Foil Braid
  • High performance cable
    16.4 ft (5 m) Premium Certified High-Speed HDMI cable with Ethernet supports 4K 60 Hz (3 840 x 2 160), 18 Gbps bandwidth, HDR10, ultra-wide aspect ratio, ARC, 3D video, 32 Ch audio (5.1/7.1/Dolby TrueHD/Atmos), BT.2020 colorimetry.
  • Premium HDMI cable
    Ultra HD 4K 60 Hz HDMI cord is engineered and built to improve signal integrity. Featuring connector bodies encased in die-cast aluminum to prevent EMI induced signal degradation, corrosion-resistant gold-plated connectors.
  • Durable
    Tested to withstand 10,000+ insertions and 600+ bend cycles at 120° angle. Durable TPE jacket with soft molded TPE strain reliefs counters the stress of frequent bends. TPE is non-toxic and halogen free.
  • Applications
    Ideal for home/office, works with computer/laptop/desktop/PC/workstation, UHD HDMI cord to connect TV/monitor/display/projector, Samsung/Sony/Apple TV/Dell/LG. Works with HDMI Ultra HD, and other resolutions.
StarTech.com 16ft (5m) Premium Certified HDMI 2.0 Cable - High-Speed Ultra HD 4K 60Hz HDMI Cable with Ethernet - HDR10, ARC - UHD HDMI Video Cord - For UHD Monitors, TVs, Displays - M/M - HDMI cable with Ethernet - 5 m
Cable
Premium High Speed - HDMI cable with Ethernet
Shielded
American Wire Gauge (AWG)
28
Length
5 m
Grey, black
Connector
HDMI - male
Connector (Second End)
HDMI - male
Passive cable, 4K60Hz (3840 x 2160) support
Cable Type
Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz (3840 x 2160) support
Shielded
28
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
Length
5 m
Plated Connector
Gold
Audio Return Channel (ARC), Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, support HDR10, Dolby DTS 5.1 support, Dolby DTS:X support, 3D ready, colourimetry BT.2020 support, 18 Gbps data rate, Dolby DTS 7.1 support, strain relief, outer diameter 6.5mm
Grey, black
Connector
19 pin HDMI Type A - male
RoHS, WEEE, EMI
Shipping Width
39.5 cm
Shipping Depth
13.8 cm
Shipping Height
7 cm
Shipping Weight
230 g
Limited warranty - lifetime
GXT0 StarTech.com 13ft/4m Premium Certified HDMI 2.0 Cable In Stock £17.11
Length: 5m
