StarTech.com 16-Port USB-Serial Adapter Hub
Quicklinx: C7C5WS00 Mfr#: ICUSB23216FD
Wired / Wireless: Wired
Protocol: RS-232
Compatibility: Mac, PC, Unix
Type: Serial adapter
Hurry, only 2 left in stock!
£303.34 ex VAT
£364.00 inc VAT
Convert a USB port into 16 RS232 serial ports in an industrial rack-mountable chassis - and daisy chain multiple hubs for a scalable solution. Here's an easy and cost-efficient way to add RS232 serial capability to your industrial setting. This 16-port USB-to-serial adapter hub features a sturdy, rack-mountable chassis, and supports daisy chaining, so you can connect multiple hubs together to increase your serial device port count.
This rack-mountable USB serial hub (FTDI) lets you add 16 serial ports (RS232), with full control from your desktop or laptop computer system using a single USB port. The daisy-chain function gives you a cost-effective and scalable way to increase your serial port count and expand as your needs grow, without investing in a higher cost serial hub.
Providing full control of your serial components from a single device, the USB serial hub is ideal for a multitude of applications including: industrial automation, self-serve automated kiosks, and monitoring of cameras and security systems.
The hub features COM port retention, which retains the assigned serial COM port values. This ensures that the same values are automatically re-assigned to the port provided by the adapter, in the event it is disconnected and re-connected to the host computer.
The hub features a reliable FTDI USB-to-serial chipset, which provides easy installation into a broad range of operating systems.
With its all-metal chassis, this rugged, rack-mountable hub fits into standard 19-inch server storage racks to provide an efficient industrial serial solution. It supports an extended operating temperature range of 40°C to 85°C (-40°F to 185°F), ensuring reliable performance even in the harshest environments. The USB-serial hub includes both an AC adapter and terminal block power, providing versatile power options.
StarTech.com 16 Port USB to Serial Adapter Hub - USB to RS232 Daisy Chain - serial adapter
Serial adapter
Rack-mountable
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 16
12 cm x 43 cm x 4.5 cm
1.52 kg
Australia, North America, United Kingdom, Europe
RS-232
Data Transfer Rate
480 Mbps
FT232RL - FTDI
AC 120/230 V / DC 12 V
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14, Linux 2.4.x - 4.9.x LTS versions only
Serial adapter
Rack-mountable
USB 2.0
Ports
RS-232 x 16
Wired
RS-232
Data Transfer Rate
480 Mbps
Status Indicators
Transmit, receive
128-byte FIFO
Processor / Memory
FT232RL - FTDI
16 x RS-232 - 9 pin D-Sub (DB-9) (front) , 1 x USB 2.0 - 4 pin USB Type B (front)
2 rack mount brackets, rack mounting screws, DIN rail mounting screws, DIN rail mounting brackets
1 x USB cable , 1 x power adapter
FCC, RoHS, WEEE, RCM
Software Included
Drivers & Utilities
12 cm
43 cm
4.5 cm
1.52 kg
-10 °C
80 °C
5 - 85%
C7C5 StarTech.com 4 Port Wall Mountable USB to Serial Adapter Hub with COM Retention In Stock £62.04
C7C5 StarTech.com 8 Port PCI Express Low Profile Serial Adapter Card In Stock £126.12
C7C5 StarTech.com 8 Port USB to RS232 Serial DB9 Adapter Hub In Stock £139.71
C7C5 StarTech.com 16-Port USB-Serial Adapter Hub In Stock £303.34
C7C5 StarTech.com 4 Port USB to Serial Hub In Stock £52.67
Protocol: RS-232
Compatibility: Mac
Compatibility: PC
Compatibility: Unix
Price Range Ex VAT: 300 - 500
