Convert a single USB port into 16 RS232 serial ports in a hardened industrial-grade rack-mountable chassis. The ICUSB23216F 16-Port Rack Mountable FTDI USB Serial Hub (FTDI) adds 16 RS232 Serial ports with data transfer rates up to 921.6 Kbps, for control by a desktop or laptop computer system using a single USB port. This durable, hardened USB to RS232 hub offers an all metal chassis, which fits into standard 19-inch server storage racks for an organized industrial USB to COM port solution, and supports an extended -40?°C to 85?°C (-40?°F to 185?°F) operating temperature range that allows for reliable use in even the harshest environments. The hub features COM port retention, retaining assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. The USB-serial hub includes both an AC adapter and Terminal Block power options and features a reliable FTDI USB to serial chipset that offers simple installation into a broad range of operating systems including Windows, Linux and Mac OS.
- StarTech.com 16 Port Rackmount FTDI USB to Serial COM Adapter Hub - RS232 Multiplexer - serial adapter - USB 2.0 - RS-232 x 16
- Serial adapter
- Form Factor
- Rack-mountable
- Interface (Bus) Type
- USB 2.0
- Ports
- RS-232 x 16
- 12 cm x 4.5 cm x 43 cm
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Black
- Power
- AC 120/230 V
- System Requirements
- Apple MacOS 9.x, Apple MacOS X, Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
- 2-year warranty
- Serial adapter
- Form Factor
- Rack-mountable
- USB 2.0
- Ports
- RS-232 x 16
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- 16 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
- 1 x USB - 4 pin USB Type B
- Mounting Kit
- Included
- FCC, RoHS
- Black
- Power Device
- Power adapter - external
- Voltage Required
- AC 120/230 V
- OS Required
- 12 cm
- 4.5 cm
- 43 cm
- Limited warranty - 2 years
- -40 °C
- 85 °C
- 0 - 60%
