Add 16 RS232 serial ports (DB9) to your low or full-profile computer, through a PCI Express slot. This PCI Express serial card adds 16 high-speed RS232 ports to your standard or low-profile desktop or server PC. This lets you maximize the number of available DB9 RS232 ports that are available for connecting your serial-based devices and equipment, while using only a single PCI Express (PCIe) slot. It's the perfect solution for adding the serial ports you need, even if your desktop PC or server only has a limited number of PCIe expansion slots.
You can install the serial card to add 16 high-performance DB9 RS232 serial ports from a single PCIe slot. With two breakout cables of 8 ports each, the PCIe serial card maximizes the density of DB9 RS232 ports on a server or desktop computer. It's ideal for system upgrades in a wide range of applications, including manufacturing equipment, POS equipment, security devices such as surveillance cameras, and environment or building control systems.
The serial card is compliant with PCI Express 1.0a specification, and it's compatible with 1x, 2x, 4x, 8x and 16x PCI Express slots.
The PCIe serial card delivers high-performance, high-speed serial communication, with support for data transfer rates of up to 921.6 Kbps.
The serial card is easy to install and configure, and compatible with a broad range of Windows and Linux operating systems. The card features IRQ sharing and supports plug-and-play serial device connections, which makes it convenient and easy to connect serial devices. It includes a low-profile bracket making it compatible with both full profile and low profile PC chassis slots.
Add 16 RS232 ports through one PCIe slot
You can install the serial card to add 16 high-performance DB9 RS232 serial ports from a single PCIe slot. With two breakout cables of 8 ports each, the PCIe serial card maximizes the density of DB9 RS232 ports on a server or desktop computer. It's ideal for system upgrades in a wide range of applications, including manufacturing equipment, POS equipment, security devices such as surveillance cameras, and environment or building control systems. The serial card is compliant with PCI Express 1.0a specification, and it's compatible with 1x, 2x, 4x, 8x and 16x PCI Express slots. -
High-speed serial communication
The PCIe serial card delivers high-performance, high-speed serial communication, with support for data transfer rates of up to 921.6 Kbps. -
Easy installation
The serial card is easy to install and configure, and compatible with a broad range of Windows and Linux operating systems. The card features IRQ sharing and supports plug-and-play serial device connections, which makes it convenient and easy to connect serial devices. It includes a low-profile bracket (installed), and a full-profile bracket (included in the package), making it compatible with both low profile and full profile PC chassis slots. The PEX16S550LP is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 16 Port PCI Express Serial Card - High-Speed PCIe Serial Card - expansion module - PCIe 1.1 - RS-232 x 2
- Expansion module
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express 1.1 x1
- PCI Specification Revision
- PCIe 1.1
- Ports
- RS-232 x 2
- 2.2 cm x 16.77 cm x 6.8 cm
- 70 g
- Data Link Protocol
- RS-232
- Data Transfer Rate
- 921.6 Kbps
- Yellow
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.6.x to 4.2.x LTS versions
- Expansion module
- Form Factor
- PCIe 1.1
- Ports
- RS-232 x 2
- Connectivity Technology
- Wired
- RS-232
- 921.6 Kbps
- 2 x RS-232 - 68 PIN VHDCI (Mini-Centronics)
- Included Accessories
- Low-profile bracket
- Cables Included
- 2 x VHDCI to 8 x DB-9 cable (external)
- FCC, RoHS, WEEE, RCM
- Yellow
- OS Required
- 2.2 cm
- 16.77 cm
- 6.8 cm
- 70 g
- 0 °C
- 55 °C
- 10 - 90% (non-condensing)
