StarTech.com 16 Port 1U Rackmount USB PS/2 KVM Switch with OSD
Quicklinx: 4MHPWS00 Mfr#: SV1631DUSBGB
Type: KVM switch
Ports: 16
Connectivity: KVM
£488.55 ex VAT
£586.26 inc VAT
Manage all your computers from one convenient location with a StarTech.com KVM switch. The Startech.com SV1631DUSBGB let you connect 16 USB or PS/2 computers using only one USB keyboard, mouse, and monitor. Convenient pushbutton and hot-key commands allow for quick, reliable switching between your systems. Manual and Auto scan modes are supported. Our slim design needs only 1U in your cabinet and uses rear cable connections for maximum space efficiency.
Multiple SV1631DUSBGB units can be cascaded to support up to 136 computers
StarTech.com 16 Port 1U RackMount USB PS/2 KVM Switch with OSD - KVM switch - 16 ports
KVM switch - 16 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
1 local user
43.8 cm x 18 cm x 4.5 cm
3.1 kg
United Kingdom
3-year warranty
P/N: 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK12OD, RK2236BKF, RK2536BKF, RK3236BKF, RK4236BK, RK4242BK, RK960CP, RKQMCAB12, RKWOODCAB12
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Status Indicators
Port status
16 x KVM HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
External power adapter
United Kingdom
43.8 cm
18 cm
4.5 cm
3.1 kg
Limited warranty - 3 years
5 °C
4MHP StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.85
4MHP StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.54
4MHP StarTech.com DC Power Adapter - 9V, 2A In Stock £12.30
Type: KVM switch
Ports: 16
Connectivity: KVM
