This 16 Port USB KVM Switch offers a dependable computer management tool that allows you to control up to 16 USB connected computers from one keyboard, mouse and monitor. The KVM switch offers maximum control, allowing you to switch computers using hotkey commands or front panel push-buttons, and offers the added configurability and convenience of an On Screen Display. A suitable addition to server room operations, the 16 port switch can be rackmounted into 1U of cabinet space, and can be cascaded with multiple KVM switches to deliver control of up to 136 computers from this single switch.
- StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD (SV1631DUSBU) - KVM switch - 16 ports
- KVM switch - 16 ports - cascadable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display
- Power
- AC 120/230 V
- 54 cm x 18 cm x 4.5 cm
- 3.1 kg
- Black
- 3-year warranty
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25U, 4POSTRACK42, IM12D1500P, RACKCOND1701, RACKCOND17HD, RK1233BKM, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RKCONS1701, RKCONS17HD, RKCONS1901, RKCONS1908K, RKCONS1916K, SVA12M2NEUA, SVA12M5NA
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 16 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440
- On-Screen Display
- Status Indicators
- Port status, power
- 16 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Rack Mounting Kit
- Included
- FCC, RoHS
- 54 cm
- 18 cm
- 4.5 cm
- 3.1 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- Designed For
- P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, IM12D1500P, RACKCOND1701, RACKCOND17HD, RACKCONV1701, RK1233BKM, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RKCONS1701, RKCONS17HD, RKCONS1901, RKCONS1908K, RKCONS1916K, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £10.67 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £15.89 |
StarTech.com 4 Port Professional VGA USB KVM Switch with Hub | In Stock | £94.48 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD | In Stock | £551.61 |
StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £576.36 |
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables | In Stock | £319.24 |
StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch | In Stock | £657.51 |
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable | In Stock | £8.00 |
StarTech.com DC Power Adapter - 12V, 2A | In Stock | £12.66 |
StarTech.com DC Power Adapter - 12V, 5A | In Stock | £41.16 |
