Product
StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F
Quicklinx: 4JRBWS00 Mfr#: USB2FAAEXT15
Length: 4.6m
More than 50 in stock
£13.61 ex VAT
£16.33 inc VAT
Standard delivery Delivered within 3-5 working days
Reliably extend the distance of a USB 2.0 device an additional 15ft. This 15ft USB 2.0 Active Extension Cable offers one USB A male connector and one USB A female connector, providing an active, bus-powered extension of a USB 2.0 device connection by up to 15ft (4.5m).
The extension cable (USB Extender) supports high speed USB 2.0 transfer rates of up to 480Mbps.
StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F - USB extension cable - 4.6 m
USB extension cable
Active cable (signal regeneration)
Length
4.6 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
2 years warranty
P/N: PEXUSB7LP, SAT3520U2RGB, USBPS2PLATE, USB2IR2, ICUSB2321X, UNI3510U2, SAT3520U2R, SAT3510U2, ICUSB1284D25, ICUSB2328, ICUSB2324, SAT3510U2B, 35FCREAD20, ICUSB232PRO, SATCAS35U2GB, ICUSB232C2, 35FCREAD20BK, SATCASE35U2, USB555WG, ICUSB232_2, USBPS2PC, 35FCREAD, 35FCREADBK, FCREADMINI, ICUSB232
USB extension cable
Length
4.6 m
Connector
USB / USB 2.0, Plug and Play, FCC
2 years warranty
StarTech.com 2 Port USB to RS232 Serial DB9 Adapter Cable, 20-in-1 3.5" Bay Flash Memory Card Reader, 3.5in USB to SATA External Hard Drive Enclosure w/ One Button Backup, 35FCREAD, 35FCREADBK, 4 Port USB to RS-232 Serial DB9 Adapter, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, 7-in-1 USB 2.0 Multi Media Memory Card Reader, 8 Port USB to RS232 Serial DB9 Adapter Hub, USB to Infrared/IrDA SIR Adapter, USB to PS/2 Keyboard and Mouse Adapter Cable, USB to PS/2 Keyboard and Mouse Converter Adapter, USB Wireless Network Adapter , StarTech.com InfoSafe 3.5" USB 2.0 SATA Hard Drive Enclosure, 3.5" USB 2.0 to IDE/SATA Hard Drive Enclosure, 3.5" USB 2.0 to SATA Drive Enclosure, USB 2.0 Dual 3.5" SATA Drive Enclosure w/RAID
Length: 4.6m
Price Range Ex VAT: 0 - 50
