StarTech.com 15U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth
Quicklinx: FP9BWS00 Mfr#: 4POSTRACK15U
Hurry, only 1 left in stock!
£187.45 ex VAT
£224.94 inc VAT
Computer Equipment Rack Casters Leveling Feet Cable Management Hooks. The 15U open frame rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Easy to Assemble
Designed with ease of use in mind, this 15U 4 post rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40 in.) that make it easy to adapt the adjustable server rack to fit your equipment.
Durable Design
This durable free standing server rack supports a static loading capacity of up to 1200 lb. (544 kg) and portable rolling weight capacity of 660 lb. (300 kg). The rack also features offers compliance with the EIA/ECA-310 standard for a universal design that's compatible with most network equipment rack equipment.
For a complete server storage solution that saves you time and hassle, the mobile server rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability while free standing.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
Backed by a StarTech.com 2-year warranty and free lifetime technical support.
  • Easy to Assemble
  • Durable Design
    This durable free standing server rack supports a static loading capacity of up to 1220 lb. (544 kg) and portable rolling weight capacity of 660 lb. (300 kg). The rack also features offers compliance with the EIA/ECA-310 standard for a universal design that's compatible with most network equipment rack equipment. For a complete server storage solution that saves you time and hassle, the mobile server rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability while free standing.
  • The Choice of IT Pros Since 1985
    StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales. Backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 15U 19" Open Frame Server Rack, 4 Post Adjustable Depth 22-40" Mobile, Free Standing Rolling Network/Computer Equipment Data Rack, Dell PowerEdge, HP ProLiant ThinkServer - Adjustable Server Rack (4POSTRACK15U) - rack - 15U
Rack
Rack Type
Open frame - 4-post
Placing / Mounting
Floor-standing
Package Content
Phillips screwdriver, 2 top brackets, 8 corner sections, M8 (13mm) wrench, 4 casters, 4 x levelling feet, M6 (10mm) wrench, 2 right vertical rails, 2 left vertical rails, 4 grounding wires, 24 M6 cage nuts, 4 lock washers, 8 cable management hooks, 18 M6 flange nuts, 18 M6 flat washers, 18 M6 Hex screws, 8 hook mounting screws, 50 M8 Hex screws, 4 Phillips head screws, 24 M6 screws, 24 M6 plastic washers, 8 center sections, 50 M8 flat washers
Height (Rack Units)
15U
Product Material
Steel
60 cm x 1.119 m x 77.1 cm
24.7 kg
Integrated cable management, adjustable mounting rails
Rack
Rack Type
Open frame
Rack Post Qty
4-post
Placing / Mounting
Floor-standing
Product Material
Steel
Package Content
Height (Rack Units)
15U
60 cm
1.119 m
77.1 cm
24.7 kg
27.5 cm x 87 cm x 12.5 cm / 27.6 kg
Weight Limit
544 kg
EIA-310-C, RoHS, REACH, ECA-310-E
Limited warranty: - 2 years
FP9B StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg In Stock £92.31
FP9B StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.91
FP9B StarTech.com 1U Rack Blank Panel for 19in Server Racks and Cabinets In Stock £8.29
FP9B StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £55.25
FP9B StarTech.com 1U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £61.35
FP9B StarTech.com 2U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £70.88
FP9B StarTech.com 3U Fixed 19" Adjustable Depth Universal Server Rack Rails In Stock £75.13
FP9B StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £17.22
FP9B StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - Heavy Duty - 250lbs / 113kg In Stock £79.75
FP9B StarTech.com 2U 16in Universal Vented Rack Mount Cantilever Shelf - Fixed Rack Shelf - 50lbs / 22kg In Stock £36.09
FP9B StarTech.com 2U Rack Mount Cantilever Shelf - Heavy Duty Fixed Server Rack Shelf - 125lbs / 56kg In Stock £50.11
FP9B StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £46.00
FP9B StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.31
FP9B StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £22.90
FP9B StarTech.com 19in Cable Management Panel In Stock £23.58
FP9B StarTech.com 25ft. Hook-and-Loop Cable Tie In Stock £4.35
FP9B StarTech.com 50ft. Hook-and-Loop Cable Tie In Stock £8.85
FP9B StarTech.com 100ft. Hook-and-Loop Cable Tie In Stock £17.53
FP9B StarTech.com M6 Rack Screws and Cage Nuts In Stock £15.09
FP9B StarTech.com Vented 1U Rack Shelf - 16 in. In Stock £31.05
FP9B StarTech.com Vented 1U Rack Shelf - 10in In Stock £20.54
FP9B StarTech.com 1U Server Rack Rails with Adjustable Depth - 4 post In Stock £45.26
FP9B StarTech.com 1U Server Rack Shelf - 16in. Deep - EIA/ECA-310 Compliant In Stock £39.40
FP9B StarTech.com 18U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £191.84
FP9B StarTech.com 8U Open Frame Rack - 4 Post - 22-40 in. Adjustable Depth In Stock £148.60
