Connect 4 USB 2.0 devices up to 15-meters away from your computer. The USB2EXT4P15M 15m Active USB 2.0 Extension Cable features an integrated 4-Port Hub that lets you connect up to 4 USB 2.0 devices while overcoming distance restrictions and power source limitations.
The active USB 2.0 extension cable ensures performance beyond the 5-meter length limits of standard USB cables. Perfect for applications where you need to extend the connection distance of your USB peripherals, enabling you to connect them up to 15-meters (50-feet) away from the host computer.
Plus, the cable allows you to maximize the number of devices connected to your computer by allowing you to connect up to 4 devices through a single connection. For added convenience, the cable comes with a 2A power adapter to provide power to your 4 connected USB devices.
The USB2EXT4P15M cable supports the full USB 2.0 bandwidth of 480 Mbps.
 - StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub - Long USB Cable with 4 port USB Hub - USB A (M) to 4x USB A (F) - 15m, 50 ft Black (USB2EXT4P15M) - hub - 4 ports
 - Hub - 4 ports
- Subtype
 - USB
- Ports
 - 4 x USB 2.0
- Performance
 - Maximum data rate: 480 Mpps
 - Over-current protection
- Power
 - AC 120/230 V
 - 700 g
 - Black
 - 2-year warranty
- Designed For
 - P/N: SVA5H2NEUA
 - Hub - 4 ports
- Enclosure Type
 - Desktop
- Subtype
 - USB
- Ports
 - 4 x USB 2.0
- Performance
- Status Indicators
 - Active
 - 4 x USB 2.0 Type A
- Voltage Required
 - AC 120/230 V
 - Black
- Cables Included
 - 1 x SuperSpeed USB cable - 15 m
 - Plug and Play, FCC, RoHS
 - 700 g
 - Limited warranty - 2 years
- Designed For
 - P/N: SVA5H2NEUA
                        StarTech.com DC Power Adapter - 5V, 2A | In Stock | £9.67 |
                        StarTech.com USB Extender Hub, 10m, USB 3.0 | In Stock | £116.04 |
