StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub
Quicklinx: 9PS1WS00 Mfr#: USB2EXT4P15M
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
Form Factor: External
£77.21 ex VAT
£92.65 inc VAT
Connect 4 USB 2.0 devices up to 15-meters away from your computer. The USB2EXT4P15M 15m Active USB 2.0 Extension Cable features an integrated 4-Port Hub that lets you connect up to 4 USB 2.0 devices while overcoming distance restrictions and power source limitations.
The active USB 2.0 extension cable ensures performance beyond the 5-meter length limits of standard USB cables. Perfect for applications where you need to extend the connection distance of your USB peripherals, enabling you to connect them up to 15-meters (50-feet) away from the host computer.
Plus, the cable allows you to maximize the number of devices connected to your computer by allowing you to connect up to 4 devices through a single connection. For added convenience, the cable comes with a 2A power adapter to provide power to your 4 connected USB devices.
The USB2EXT4P15M cable supports the full USB 2.0 bandwidth of 480 Mbps.
StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub - Long USB Cable with 4 port USB Hub - USB A (M) to 4x USB A (F) - 15m, 50 ft Black (USB2EXT4P15M) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 2.0
Performance
Maximum data rate: 480 Mpps
Over-current protection
AC 120/230 V
700 g
P/N: SVA5H2NEUA
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 2.0
Performance
Status Indicators
Active
4 x USB 2.0 Type A
AC 120/230 V
1 x SuperSpeed USB cable - 15 m
Plug and Play, FCC, RoHS
700 g
P/N: SVA5H2NEUA
9PS1 StarTech.com DC Power Adapter - 5V, 2A In Stock £10.11
9PS1 StarTech.com USB Extender Hub, 24m, USB 2.0 In Stock £126.76
9PS1 StarTech.com USB Extender Hub, 10m, USB 3.0 In Stock £122.30
Type: USB Hub
Interface: USB 2.0
Speed: 480Mbps
Ports: 4
