Brand
StarTech.com 15m Snagless Cat6 Patch Cable - Green
Quicklinx: 819CWS00 Mfr#: N6PATC15MGN
Length: 15m
Colour: Green
Hurry, only 2 left in stock!
£19.93 ex VAT
£23.91 inc VAT
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC15MGN Cat 6 Patch Cable (15m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable green PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
  • 100% copper - a better value
    StarTech.com Cat6 cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
  • 24 AWG wire
    This Cat6 cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
  • 50-micron gold connectors
    This Cat 6 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com 15m CAT6 Ethernet Cable, 10 Gigabit Snagless RJ45 650MHz 100W PoE Patch Cord, CAT 6 10GbE UTP Network Cable w/Strain Relief, Green, Fluke Tested/Wiring is UL Certified/TIA - Category 6 - 24AWG (N6PATC15MGN) - patch cable - 15 m - green
Patch cable - CAT 6
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Green
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Molded, snagless
Length
15 m
Green
Connector
RJ-45 - male
RJ-45 - male
RoHS, ETL - up to 500 MHz
819C StarTech.com 15m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £19.91
819C StarTech.com 15m Snagless Cat6 Patch Cable - Orange In Stock £19.93
819C StarTech.com 15m Snagless Cat6 Patch Cable In Stock £20.16
819C StarTech.com 15m Snagless Cat6 Patch Cable - Green In Stock £19.93
819C StarTech.com 15m Grey Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £19.49
819C StarTech.com 15m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable In Stock £19.73
819C StarTech.com 15m Snagless Cat6 Patch Cable - Yellow In Stock £20.44
819C StarTech.com 15m Snagless Cat6 Patch Cable - White In Stock £19.49
Length: 15m
Colour: Green
Stock Status: In stock
