StarTech.com 15m Red Slim CAT6 Cable
Quicklinx: J7W0WS00 Mfr#: N6PAT15MRDS
£19.60 ex VAT
£23.52 inc VAT
This slim CAT6 cable meets all Category 6 patch cable specifications to deliver a reliable Gigabit and Power over Ethernet (PoE) network connection in high-density network installations. Improved Airflow The Slim Cat6 Patch Cord is 36% thinner than standard Cat6 Ethernet cables, enabling greater airflow and heat dissipation in confined spaces. The Slim Cat6 Ethernet cable is also more flexible, for easier cable routing in crowded network racks and patch panels. This cable features snagless connectors that protect the RJ45 clips during installation, reducing snags or breakage when routing through narrow gaps or in between devices. Durable Construction The Slim Cat6 Cable features 50-micron gold RJ45 contacts that ensure a precise fit to minimize wear and signal loss. The 4-pair Unshielded Twisted Pair (UTP) construction utilizes 28AWG Pure Bare Copper Wire for improved conductivity and low resistance. The flexible Low Smoke Zero Halogen (LSZH) flame-retardant jacket emits low smoke and toxic fumes when exposed to extreme heat or in the event of a fire. This enables safer installations in poorly-ventilated areas including some industrial settings, self-contained environments such as trains and aircraft, as well as residential settings where compliance with building codes must be considered. Tested for Reliability
The Slim CAT6 patch cable is tested to comply with ANSI/TIA 568 C.2 requirements for guaranteed Cat6 performance. The cable is Fluke Tested to ensure minimal Near-End Crosstalk (NEXT) and Retun Loss (RL). Reliably deliver up to 90W of PoE++ to power a remote networking devices, including PoE switches and boardroom cameras. This Slim Cat6 Patch Cable complies with IEEE 802.3bt Type 4 PoE++ specifications.
  • Improved Airflow
  • Durable Construction
  • Tested for Reliability
StarTech.com 15m Red Slim CAT6 Ethernet Cable, Snagless, 28AWG, LSZH - patch cable - 15 m - red
Patch cable - CAT 5/5e/6 - IEEE 802.3bt
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Snagless, halogen-free, stranded copper, 100W PoE++ support, pure bare copper conductors, test fluke pass, flame retardant, minimised Near-End Crosstalk (NEXT), reduced Return Loss (RL), up to 1 Gbps, strain relief
Length
15 m
Diameter
3.6 mm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
American Wire Gauge (AWG)
28
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
15 m
Diameter
3.6 mm
Red
Connector
RJ-45 - male
RJ-45 - male
ANSI/TIA-568-C.2, IEEE 802.3bt Type 4, RoHS, TIA/EIA-568-B.1-2001 - up to 250 MHz
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
5 cm
Shipping Weight
254 g
10 °C
60 °C
