StarTech.com 15m OM4 Multimode Fiber Cable
Quicklinx: J7Y3WS00 Mfr#: OM4RLCLC15M
£35.71 ex VAT
£42.85 inc VAT
This OM4 LC to LC Multimode Duplex Fiber Optic Patch cable delivers reliable connectivity across 40 and 100 Gigabit networks. The TIA-standard Erika Violet jacket clearly distinguishes OM4 from Aqua OM3/OM4 cabling, eliminating guesswork in critical network setups. The compact uniboot connector design enables easy insertion and removal in high-density installations. Engineered for Optimal Performance Built with laser-optimized multimode fiber (LOMMF), the OM4 fiber patch cable is ideal for 850 nm and 1350 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. Precision-manufactured ceramic ferrules maintain accurate fiber alignment to prevent connectivity issues and minimize insertion loss. Designed for reliability in high-density network applications, the LC to LC UPC polished fiber ends greatly improves return loss characteristics over older PC polishing techniques which may negatively affect performance. OFNR Riser Rated Housed in an OFNR (Optical Fiber Nonconductive Riser) flame-retardant jacket, this Riser-rated OM4 fiber cable is engineered to minimize vertical flame propagation between building floors. It enables safer cable installations in riser spaces and vertical shafts within commercial buildings, supporting compliance with fire codes in multi-story structures and other regulated environments. Wide Compatibility This multimode 50/125µm fiber optic patch cord is backward compatible with OM3 and 1/10/40 Gbps networks, facilitating reliable data transmission in legacy fiber environments. Our fiber cables undergo rigorous testing to verify operation within strict optical insertion loss limits, ensuring compatibility and 100% reliability.
  • Engineered for Optimal Performance
  • OFNR Riser Rated
  • Wide Compatibility
    This multimode 50/125µm fiber optic patch cord is backward compatible with OM3 and 1/10/40 Gbps networks, facilitating reliable data transmission in legacy fiber environments. StarTech.com fiber cables undergo rigorous testing to confirm operation within strict optical insertion loss limits, guaranteeing compatibility and 100% reliability.
StarTech.com 15m (49.2ft) LC/LC (UPC) OM4 Multimode Fiber Optic Cable - patch cable - 15 m - erika violet
Patch cable - OM4 - OFNR
Duplex fibre optic
Type of Fibre Optics
Multimode
Jumper, up to 100 Gbps, Laser-optimized multimode fibre (LOMMF), VCSEL transmitter, flame retardant, EMI protection, strain relief, bending radius 7.5mm, wavelength of 850/1300 nm
Length
15 m
Diameter
1.6 mm
Core / Cladding Diameter
50 / 125 micron
Connector
LC/UPC duplex multi-mode - male
Connector (Second End)
Erika violet
Network Cable Type
Duplex fibre optic
Multimode
Jacket Material
PVC
50 / 125 micron
Length
15 m
Diameter
1.6 mm
121.2 g
Erika violet
Connector
RoHS, OFNR
Shipping Width
23 cm
Shipping Depth
18 cm
Shipping Height
2 cm
Shipping Weight
121.2 g
-20 °C
60 °C
J7Y3 StarTech.com 10m OM4 Multimode Fiber Cable In Stock £28.11
J7Y3 StarTech.com 20m OM4 Multimode Fiber Cable In Stock £43.98
J7Y3 StarTech.com 2m OM4 Multimode Fiber Cable In Stock £15.05
J7Y3 StarTech.com 30m OM4 Multimode Fiber Cable In Stock £61.40
J7Y3 StarTech.com 3m OM4 Multimode Fiber Cable In Stock £16.31
J7Y3 StarTech.com 40m OM4 Multimode Fiber Cable In Stock £77.98
J7Y3 StarTech.com 50m OM4 Multimode Fiber Cable In Stock £94.75
J7Y3 StarTech.com 7m OM4 Multimode Fiber Cable In Stock £22.65
