This OM4 LC to LC Multimode Duplex Fiber Optic Patch cable delivers reliable connectivity across 40 and 100 Gigabit networks. The TIA-standard Erika Violet jacket clearly distinguishes OM4 from Aqua OM3/OM4 cabling, eliminating guesswork in critical network setups. The compact uniboot connector design enables easy insertion and removal in high-density installations. Engineered for Optimal Performance Built with laser-optimized multimode fiber (LOMMF), the OM4 fiber patch cable is ideal for 850 nm and 1350 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. Precision-manufactured ceramic ferrules maintain accurate fiber alignment to prevent connectivity issues and minimize insertion loss. Designed for reliability in high-density network applications, the LC to LC UPC polished fiber ends greatly improves return loss characteristics over older PC polishing techniques which may negatively affect performance. OFNR Riser Rated Housed in an OFNR (Optical Fiber Nonconductive Riser) flame-retardant jacket, this Riser-rated OM4 fiber cable is engineered to minimize vertical flame propagation between building floors. It enables safer cable installations in riser spaces and vertical shafts within commercial buildings, supporting compliance with fire codes in multi-story structures and other regulated environments. Wide Compatibility This multimode 50/125µm fiber optic patch cord is backward compatible with OM3 and 1/10/40 Gbps networks, facilitating reliable data transmission in legacy fiber environments. Our fiber cables undergo rigorous testing to verify operation within strict optical insertion loss limits, ensuring compatibility and 100% reliability.
Built with laser-optimized multimode fiber (LOMMF), the OM4 fiber patch cable is ideal for 850 nm and 1350 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. Precision-manufactured ceramic ferrules maintain accurate fiber alignment to prevent connectivity issues and minimize insertion loss. Designed for reliability in high-density network applications, the LC to LC UPC polished fiber ends greatly improves return loss characteristics over older PC polishing techniques which may negatively affect performance. -
OFNR Riser Rated
Housed in an OFNR (Optical Fiber Nonconductive Riser) flame-retardant jacket, this Riser-rated OM4 fiber cable is engineered to minimize vertical flame propagation between building floors. It enables safer cable installations in riser spaces and vertical shafts within commercial buildings, supporting compliance with fire codes in multi-story structures and other regulated environments. -
Wide Compatibility
This multimode 50/125µm fiber optic patch cord is backward compatible with OM3 and 1/10/40 Gbps networks, facilitating reliable data transmission in legacy fiber environments. StarTech.com fiber cables undergo rigorous testing to confirm operation within strict optical insertion loss limits, guaranteeing compatibility and 100% reliability.
- StarTech.com 15m (49.2ft) LC/LC (UPC) OM4 Multimode Fiber Optic Cable - patch cable - 15 m - erika violet
- Patch cable - OM4 - OFNR
- Technology
- Duplex fibre optic
- Type of Fibre Optics
- Multimode
- Jumper, up to 100 Gbps, Laser-optimized multimode fibre (LOMMF), VCSEL transmitter, flame retardant, EMI protection, strain relief, bending radius 7.5mm, wavelength of 850/1300 nm
- Length
- 15 m
- Diameter
- 1.6 mm
- Core / Cladding Diameter
- 50 / 125 micron
- Connector
- LC/UPC duplex multi-mode - male
- Connector (Second End)
- Erika violet
- Limited lifetime warranty
- Network Cable Type
- Technology
- Multimode
- Jacket Material
- PVC
- 50 / 125 micron
- Length
- 15 m
- Diameter
- 1.6 mm
- 121.2 g
- Erika violet
- Connector
- RoHS, OFNR
- Shipping Width
- 23 cm
- Shipping Depth
- 18 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 121.2 g
- -20 °C
- 60 °C
StarTech.com 10m OM4 Multimode Fiber Cable | In Stock | £28.11 |
StarTech.com 20m OM4 Multimode Fiber Cable | In Stock | £43.98 |
StarTech.com 2m OM4 Multimode Fiber Cable | In Stock | £15.05 |
StarTech.com 30m OM4 Multimode Fiber Cable | In Stock | £61.40 |
StarTech.com 3m OM4 Multimode Fiber Cable | In Stock | £16.31 |
StarTech.com 40m OM4 Multimode Fiber Cable | In Stock | £77.98 |
StarTech.com 50m OM4 Multimode Fiber Cable | In Stock | £94.75 |
StarTech.com 7m OM4 Multimode Fiber Cable | In Stock | £22.65 |
