StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua
Quicklinx: FF58WS00 Mfr#: 450FBLCLC15
Length: 15m
Colour: Aqua
Hurry, only 1 left in stock!
£49.31 ex VAT
£59.17 inc VAT
This LC to LC Multimode Duplex Fiber Optic Patch cable offers reliable connections for 40GBase-SR4, 100GBase-SR10, SFP+ and QSFP+ transceivers in your 40 and 100 Gigabit networks.
With laser-optimized multimode fiber (LOMMF), the patch cable is ideal for 850 nm and 1350 nm Vertical Cavity Surface Emitting Laser (VCSEL) and LED sources. The high-speed connectivity on the aqua fiber-optic cable provides a high-bandwidth solution for your data centers or high-density applications.
This fiber-optic patch cord is backward compatible with your existing 50/125 equipment, ensuring a reliable connection with legacy LANs.
Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
Each OM4 fiber cable is also individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
  • Built for Performance
  • Maximum Compatibility
  • High Quality Construction
    Housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, this fiber-optic cable ensures minimal smoke, toxicity and corrosion when exposed to high sources of heat, or in the event of a fire. It's the best choice for a wide range of environments, including industrial settings, central offices and schools, as well as residential settings where building codes are a consideration. Each OM4 fiber cable is also individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability. 450FBLCLC15 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
StarTech.com 15 m OM4 LC to LC Multimode Duplex Fiber Optic Patch Cable- Aqua - 50/125 - Fiber Optic Cable - 40/100Gb - LSZH (450FBLCLC15) - patch cable - 15 m - aqua
Patch cable - OM4
Duplex fibre optic
Type of Fibre Optics
Multimode
Laser-optimized multimode fibre (LOMMF)
Length
15 m
Core / Cladding Diameter
50 / 125 micron
Connector
2 x LC multi-mode - male
Connector (Second End)
Aqua
Network Cable Type
Patch cable - OM4
Duplex fibre optic
Multimode
Jacket Material
Low Smoke Zero Halogen (LSZH)
Fibre Qty
2
50 / 125 micron
Length
15 m
Aqua
Connector
FF58 StarTech.com 1m Aqua OM4 LC Fiber Cable In Stock £16.95
FF58 StarTech.com 2m Aqua OM4 LC Fiber Cable In Stock £19.15
FF58 StarTech.com 3m Aqua OM4 LC Fiber Cable In Stock £21.16
FF58 StarTech.com 10m OM4 LC Multimode Duplex Fiber Optic Patch Cable Aqua In Stock £37.47
FF58 StarTech.com 7m OM4 LC Multimode Duplex Fiber Optic Patch Cable - Aqua In Stock £30.33
FF58 StarTech.com 15m OM4 LC-LC Multimode Duplex Fiber Optic Patch Cable Aqua In Stock £49.31
Length: 15m
Colour: Aqua
